No network on Computer - 2 routers, 1 none CISCO router.
bistimi01
Hi guys!
I hope someone can help me on this.
First some information about what hardware i got.
I got a Cisco Router 860VAE, i got no console cable(so i'm connected to telnet), i got a home router too(Got it from my ISP).
I'm using my router i got from my ISP to the television so i can't just remove it.. anoying..
I was getting the Cisco router because i'm studying Cisco CCNA at my school(first year) and i thought it could be cool to make NetFlow
The router i got from my ISP is not advanced at all so not many options here. Anyway it use the IP range 10.0.0.0/8
Then my CISCO router use the ip range 192.168.1.0/24
The problem is that i can't get connection to the internet from my computer(I know...)
Let me show my running-config(remember I'm NEW):
Current configuration : 2500 bytes
! Last configuration change at 18:04:48 UTC Wed Jan 15 2014 by admin
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 4 tnhtc92DsfdXBhelxjLWJy3243i4ntXrpb4RdfFmfqY
no aaa new-model
wan mode ethernet
ip dhcp pool ccp_pool
import all
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8 8.8.4.4
ip flow-cache timeout active 1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
username admin privilege 15 secret 4 lUgFIkgcrt4SYXMq7jZtxq52lwdfgkj238
controller VDSL 0
shutdown
interface Loopback0
ip address 11.0.0.1 255.255.255.0
ip flow ingress
ip flow egress
interface Loopback1
no ip address
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
ip flow ingress
ip flow egress
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 2
no ip address
spanning-tree portfast
interface GigabitEthernet0
description $ETH-WAN$
ip address 10.0.0.1 255.0.0.0
ip flow ingress
ip flow egress
duplex auto
speed auto
interface Vlan1
ip flow ingress
ip flow egress
interface Vlan2
no ip address
ip flow ingress
ip flow egress
interface Dialer0
no ip address
ip flow ingress
ip flow egress
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip default-gateway 10.0.0.100
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip flow-capture vlan-id
ip flow-export source Vlan1
ip flow-export version 9
ip flow-export destination 192.168.1.3 9991
ip route 0.0.0.0 0.0.0.0 10.0.0.100
ip route 10.0.0.0 255.0.0.0 GigabitEthernet0
ip route 192.168.1.0 255.255.255.0 Vlan1
mac-address-table aging-time 15
snmp-server community public RW
snmp-server community publics RO
snmp-server ifindex persist
snmp-server enable traps config
snmp-server host 10.0.0.3 version 2c public
control-plane
banner login ^C** CISCO **^C
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 60 0
password cisco
logging synchronous
login local
transport input telnet
scheduler allocate 60000 1000
end
I've not CHANGED anything!
Some of it was just guesswork..
When i try to PING googles DNS(IP: 8.8.8.8) from the router i get
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/39/40 ms
When i try to PING googles DNS from my own computer i get
Request timed out.
Request timed out.
Request timed out.
My CISCO router ip: 192.168.1.1(vlan1) 10.0.0.1(gigabitethernet/WAN)
My ISP router ip: 10.0.0.100
My computer ip: 192.168.1.3 Gateway: 192.168.1.1
Trying to make a Topology of text MY ISP -> ISP Router -> Switch -> CISCO Router -> My Computer
It's not like i can configure RIP on my ISP router so..? And BTW, my cisco router only support RIP as a routing protocol
So what do i do?
16 Replies 16
bistimi01
It worked!
I did a reset of my router and loaded this conf:
conf t
     interface vlan1
          no shutdown
     interface gigabitethernet0
          ip address 10.0.0.99 255.0.0.0
          no shutdown
     router rip
          version 2
          network 192.168.1.0
          network 10.0.0.0
          no auto-summary
     ip dhcp pool classc_pool
          dns-server 8.8.8.8
          default-router 192.168.1.1
     service dhcp
     access-list 100 permit ip 192.168.1.0 0.0.0.255 any
     ip nat inside source list 100 interface gigabitethernet0 overload
          ip nat outside
     interface vlan1
          ip nat inside
Oliver,
Correct your configuration is correct and you can use the same
Hope you will mark this thread as marked and rate your experience.
-Ashish
