No output from "show int transceiver" from a Cat6509VE
3alee
Hello
There're more than twenty 6509VE running in the network.  All of them has got 1GE or 10GE SFP / GBIC.
However, when I tried "show int trans" in some of them, there's nothing shown:
Router_A#sh int transceiv
No transceiver present
Router_A#sh inv
Router_A#sh int status | i connected
Gi1/1                           connected    304          full   1000 1000BaseSX
Gi1/2        To WLC5508         connected    trunk        full   1000 1000BaseSX
Gi1/3        To WLC5508         connected    trunk        full   1000 1000BaseSX
Gi1/10       To WLC4404         connected    trunk        full   1000 1000BaseSX
Gi1/11       To WLC4404         connected    trunk        full   1000 1000BaseSX
Gi1/14                                  connected    961          full   1000 1000BaseSX
But from another 6509:
Router_B#sh int transceiver
Transceiver monitoring is disabled for all interfaces.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                         Optical   Optical
            Temperature  Voltage  Current   Tx Power  Rx Power
Port        (Celsius)    (Volts)  (mA)      (dBm)     (dBm)
Gi1/3         29.8       3.26      12.2       2.4     -15.2
Gi1/15        25.6       3.28       0.0       N/A       N/A
Te5/4         34.0       0.00       7.9 --   -2.3      -2.3
Te5/5         28.7       0.00       0.0       N/A       N/A
Te6/4         32.7       0.00     125.0 --    1.4     -15.3
Te6/5         26.9       0.00       0.0       N/A       N/A --
Pls help.  Thanks!
nkarpysh
There is one internal DDTS on 6k -fixed in 12.2(33)SXI. Possibly you hit that. You may want to get TAC SR opened to clarify that in more depth.
Nik
HTH,
Niko
Thanks a lot!
Those boxes will have an IOS upgrade in Dec.  Let me see if that's the cause by then.
Thanks again.
