Unable to apply service-policy: GTS Not supported on this interface
Rojer-bkk
I'm unable to apply service-policy in interface tunnel. The error return GTS not supported. Please help to guide me thanks.
policy-map QOS-PBS-512K
description Egress traffic  Branch Link To PBS 512 K
class class-default
  shape average 460000
  service-policy PBS-Br
policy-map PBS-Br
class Voice
  drop
class Signal
  drop
class Video
  drop
class MPWeb
  drop
class GROUP4
  bandwidth percent 20
class GROUP3
  bandwidth percent 65
class GROUP2
  bandwidth percent 5
class class-default
  bandwidth percent 10
Interface Tunnel 1
bandwith 512
max-reserved-bandwidth 90
8 Replies 8
Eugene Khabarov
Level 7
Level 7
GTS  is not supported on Integrated Services Digital Networks (ISDNs),  dialup interfaces, or generic routing encapsulation (GRE) tunnel  interfaces on the Cisco 7500 series router. Traffic shaping is not  supported with flow switching.
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfgts.html
This is related not only to 7500.
___
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer"
I aware about that restrict but i can apply policy on other tunnel interface such tunnel0
interface Tunnel0
description Tunnel To BBT
bandwidth 512
service-policy output QOS-BBT-512K
If you can do something, it is not means that it is supported. For example you can use GRE tunnels on catalyst switches, but it is also not supported.
Does "show policy-map interface" says something?  Can you please pate it here?
Also paste "sh ver".
___
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 14-Jun-11 19:25 by prod_rel_team
And what is about "show policy-map interface"?
The output was attached. Thanks
The source of tunnel IP from BVI interface so i think we cannot apply service-policy in that tunnel
So you've answered your question yourself )
