No packet match when configure virtual template
trinawong
Dear All,
There is no match ip address for access-list, but do see traffic passing by and BGP is established well.
There is virtual template configured for the router, below is the interface configuration:
RouterA#sh run int s0
Building configuration...
Current configuration : 332 bytes
interface Serial0
bandwidth 384
no ip address
encapsulation frame-relay IETF
ip route-cache flow
no ip mroute-cache
load-interval 30
frame-relay class MAXCIR
frame-relay traffic-shaping
no frame-relay inverse-arp
frame-relay lmi-type ansi
end
RouterA#sh run int s0.100
Current configuration : 255 bytes
interface Serial0.100 point-to-point
bandwidth 208
ip access-group ACL in
no cdp enable
frame-relay class voip
frame-relay interface-dlci 100 ppp Virtual-Template1
end
RouterA#
RouterA#sh run int virtual-access1
Current configuration : 134 bytes
interface Virtual-Access1
bandwidth 345
ip address 23.22.23.74 255.255.255.252
max-reserved-bandwidth 100
load-interval 30
end
RouterA#
RouterA#sh run int virtual-template1
Current configuration : 265 bytes
interface Virtual-Template1
bandwidth 345
service-policy output HQV_OFFICE
load-interval 30
ppp multilink
ppp multilink fragment delay 10
ppp multilink interleave
end
When i do show ip access-list ACL:
sh ip access-l ACL
Extended IP access list ACL
10 permit ip any any <<< No match
RouterA#sh int s0.100
Serial0/0/0.100 is up, line protocol is up
Hardware is GT96K Serial
MTU 1500 bytes, BW 208 Kbit, DLY 20000 usec,
reliability 255/255, txload 27/255, rxload 83/255 <<< Traffic is passing
Encapsulation FRAME-RELAY IETF
Couldn't figure out why it happened, any idea?
Thank You,
mheusinger
Level 10
Level 10
as far as I understand, you are using PPP over Frame-relay. So the FR interface will only "see" PPP traffic and your ACL - looking for IP - will get no matches.
Can you try to apply the ACL to the Virtual-Template1 and check the result?
Hope this helps! Please use the rating system.
Regards, Martin
