No protocol pppoe command?
ciscolover
Level 4
Level 4
Hi all¡¡
I'm trying to configure an Cisco 1841 with IOS 12.4 to an FTTH conection.
I would configure PPOE protocol in the vpdn-group 1 but I can't see this option in the command line ¡¡¡
Router(config-vpdn-req-in)#protocol ?
  l2tp  Use L2TP
I have read about the command "bba-group pppoe global" but i'm not sure if it has the same result. It's valid?
How can I use the bba-group pppoe global¿? I need to use it with a virtual template?
Thanks '¡¡¡¡
9 Replies 9
Peter Paluch
What exactly are you trying to configure - do you want to configure a PPPoE client or a PPPoE access concentrator?
Best regards,
Peter
Hi Peter,
I'm not an expert confiuring PPPoe on Cisco Routers. I have a comtrend router conected to ONT and I want to change it and use a Cisco 1841 router.
I think its a PPPOE client of the ISP and not a PPPOE concentrator. I have read some examples and all the examples talk about the comand "protocol ppoe" under de vpdn-group. In my router I can't include this command.
Some people talk about the command bba-group global ppoe, i think it is similar, but I'm not sure how to use it because I cannot find examples.
thanks ¡¡¡ I speak bad englis
Do not worry about your English, it's okay!
So I assume you simply want to configure your router to access internet using PPPoE. Is that right? In that case, you do not need any of the VPDN or bba-group stuff and you should in fact remove it completely from your router.
The configuration of the basic PPPoE access would be as follows (take this as an example):
interface FastEthernet0/0
description => Interface towards the ONT <=
no ip address
pppoe-client dial-pool-number 1
no shutdown
interface Dialer1
encapsulation ppp
ip address negotiated
dialer pool 1
ppp chap hostname [email protected]
ppp chap password YourPPPoEPassword
Please note that this configuration lacks many other parts that are necessary, such as NAT. If you would like me to include these then I would need to know more about your existing IP addressing, how is the 1841 connected to your network, etc.
Best regards,
Peter
Hi Peter and thanks ¡¡
I know how to configure nat, etc. No problem.
But if only you need to configure like your example, why in the link http://www.dslreports.com/faq/8199 uses vpdn-group?
And I have found another example(in spanish) and it talks exactly about my FTTH conection with a Cisco Router. It uses bba-group. I write you the Dialer1 interface. I have found 2 commands you don't include in your example(other than nat etc),
interface Dialer1
ip nat outside
ip nat enable
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname XXXXXXXXXX
ppp chap password 0 adslppp
no cdp enable
hold-queue 224 in
Could you explain me why it uses dialer-group 1  etc. Tomorrow I go to try your config...
I believe that the article showed an older, obsolete approach of configuring the PPPoE client access. The way I have shown here is the way used in today's IOS versions. The VPDN is most often used if you need to perform tunneling of PPP frames over L2TP.
Regarding the configuration snippet you have posted:
This is a command that is usually inserted automatically by IOS. It allows the IOS to keep track of packet fragments that all belong to a single original unfragmented IP packet. This allows them, for example, to pass through firewall as if the packet was unfragmented. Keep in mind that if, for example, an IP packet containing a TCP segment was fragmented, the TCP header would be located only in the first fragment. The remaining fragments have only the IP header and would therefore not be appropriately matched by those entries in the firewall that look for TCP segments. This virtual reassembly function allows the IOS to keep enough information about packets to recognize whether a sequence of fragmented packets comes from a single unfragmented packet, and apply the same action to the 2nd, 3rd, ... last fragment that was also applied to the 1st fragment - just as if the packet was unfragmented.
dialer-group 1
This command is unnecessary on PPPoE. When dial-up technologies (analog modems, ISDN) were used, this command referred to a list of "interesting" traffic that caused the router to make a call. Traffic that was not considered "interesting" could pass through the Dialer interface once the session was established but it was not capable of causing the router to make a call or to keep the call active. However, the PPPoE is not about making calls anymore - it is always on, so there is no real point in defining an interesting traffic. This command is irrelevant for PPPoE.
Actually, I should correct my suggested Dialer1 configuration. I am missing two commands: ip mtu 1492 and ip tcp adjust-mss 1452. Both these commands configure the router to pass smaller IP packets through the Dialer interface and to adjust maximum TCP segment size of TCP sessions that are carried through the PPPoE session. The reason is that the PPP and PPPoE add additional 8 bytes, and the entire PPPoE+PPP+IP+L4+L5/6/7 must be carried in an Ethernet frame whose payload size still can not exceed 1500 bytes. Hence, we need to decrease the maximum IP and TCP size by 8. The resulting Dialer1 configuration would therefore be:
interface Dialer1
 encapsulation ppp
 ip mtu 1492
 dialer pool 1
Feel welcome to ask further!
Best regards,
Peter
Hi Peter,
I have read than it's needed the conetion to the ONT tags with vlan 6 the frames. It's the data vlan of my ISP (the others are for TV and for phone).
One man configure this and it works :
-Interface fast ethernet 0/0 with encapsulation dot1q 6.
-Interface fast ethernet 0/0.6 with dialer group 1
But I have 2 problems:
-I can't write in Interface fast ethernet 0/0 encapsulation dot1q6.
-I can't associate dialer groups in interface fast ethernet 0/0.6
I have configure like this my router but it not works. Thanks for your help.
no ip address
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
vlan-id dot1q 6
  exit-vlan-config
pppoe enable
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
no cdp enable
interface Dialer1
bandwidth 6192
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname adslppp@telefonicanetpa
ppp pap sent-username adslppp@telefonicanetpa password 0 adslppp
max-reserved-bandwidth 100
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 10 interface FastEthernet0/0 overload
access-list 10 permit 192.168.1.0 0.0.0.255
Are you sure you need to tag the frames? This is usually not requried to be done on the customer's side.
no ip address
no ip route-cache
duplex auto
speed auto
vlan-id dot1q 6
  exit-vlan-config
pppoe enable
This configuration is not correct. The correct configuration is (you may paste it into your configuration, the default interface Fa0/0 will merely reset the Fa0/0 interface into the default configuration, removing all present comands):
default interface FastEthernet0/0
no shutdown
interface FastEthernet0/0.6
The rest of the configuration does not need to be changed.
In addition, the ppp authentication chap pap callin curently present on your Dialer interface is useless - please remove it. I have had lengthy discussions about the real purpose of this command in different threads:
https://supportforums.cisco.com/message/3424916#3424916
https://supportforums.cisco.com/message/3440088#3440088
Best regards,
Peter
Ok this works, thanks Peter.
1º)I have upgrade the firmware of my router to c1841-advipservicesk9-mz.124-24.T7.bin
After that I could configure encapsulation dot1q 6 and pppoe-client on subinterface 0/0.6
I will tryed to remove the chap pap callin but this works ¡¡¡
Regards.
I am glad you got it running! Good work
Regarding the ppp authentication chap pap callin - yes, I know it currently works for you. That does not mean, though, that the command is required or reasonable. This one is not and it is not supposed to be present in your configuration at all. As I explained in the two other threads, this is a common myth that keeps repeating again and again.
Best regards,
Peter
