no route to server
ohareka70
Level 3
Level 3
I have two devices on our network.  With the first device namely Sw-ArbgeTelemL3-01 i have a route back to a server namely 10.218.34.5 - but with the second device i do not have a route back.
I have a route back to 10.218.34.5 from Sw-ArbgeTelemL3-01
Sw-ArbgeTelemL3-01#sh ip route 10.218.34.5
Routing entry for 10.218.32.0/22
  Known via "ospf 1", distance 110, metric 20, type extern 2, forward metric 1015
  Last update from 172.19.254.65 on FastEthernet0/23, 1d04h ago
  Routing Descriptor Blocks:
  * 172.19.254.65, from 172.18.47.152, 1d04h ago, via FastEthernet0/23
      Route metric is 20, traffic share count is 1
But i dont have a route back from Rtr-ClakeTelem-01
Rtr-ClakeTelem-01#sh ip route 10.218.34.5
% Network not in table
Any ideas.  I have attached the configs from both devices.
Kevin
Hi ,
10.218.32.0/22 is an External route (LSA5), Rtr-ClakeTelem-01  is a ospf stub ( no LSA5 allowed )  - you will have a default route (LSA3) on this router.
> Rtr-ClakeTelem-01
router ospf 1
log-adjacency-changes
area 66 stub
area 72 stub no-summary
network 172.21.98.0 0.0.0.255 area 72
network 172.21.111.0 0.0.0.3 area 72
Dan
10 Replies 10
Hi ,
> Rtr-ClakeTelem-01
router ospf 1
area 66 stub
Dan
ohareka70
Level 3
Level 3
Dan,
Any ideas why i cant ping 10.218.34.5 from Rtr-ClakeTelem-01 which as you say has the default route but i can ping it from Sw-ArbgeTelemL3-01.
thanks
Kevin
Hi Kevin ,
- Does it respond from Rtr-ClakeTelem-01
- Does the server have a default gw ?
- Is the default gw the Rtr-ClakeTelem-01
Dan
Dan,
I cant ping 10.218.34.5 from Rtr-ClakeTelem-01 (172.21.111.2)
The server gateway is 10.218.35.0
The server is on a different subnet from Rtr-ClakeTelem-01 but its all allowed through the firewalls.
Sw-ArbgeTelemL3-01 (172.19.255.211) which is the next hop from Rtr-ClakeTelem-01 can ping it ok
Kevin
Hi Kevin,
- Do you run ospf with your firewall ?
- Sw-ArbgeTelemL3-01 : show ip ospf int b
- you should also check the firewall's routing table and permited flows
Dan
Dan,
We dont run OSPF on firewalls.  But firewall isnt the problem because Sw-ArbgeTelemL3-01 is working.
Sw-ArbgeTelemL3-01#sh ip ospf int brief
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Fa0/11       1     72              172.21.111.1/30    1     DR    1/1
Kevin
Hi Kevin ,
Sorry , I did saw afterwards that you had those details attached in your initial post.
I didn't saw any of the prefixes announced by Rtr-Clake on the Sw-ArbgeTelecom
interface Vlan1 ip address 172.21.98.254 255.255.255.224
interface Vlan61  ip address 172.21.98.62 255.255.255.192
interface Vlan62  ip address 172.21.98.190 255.255.255.192
Although I do belive that when you are pinging from Rtr-Clake the source IP used is 172.21.111.1
From your "show ip ospf int b" there is only one neighbour, but from the initial output you receive the prefix from another neighbor :
What is the neighour's ospf config ?
Dan
Dan,
The neighbour (Rtr-Clake) is 172.21.111.2.  Its is a serial link over to Sw-ArbgeTelemL3-01.  I have listed the full output from the sh ip ospf int brief command
Lo0          1     0               172.19.255.211/32  1     LOOP  0/0
Fa0/24       1     0               172.19.254.69/30   4000  DR    1/1
Fa0/23       1     0               172.19.254.66/30   1000  DR    1/1
Vl98         1     72              172.21.108.254/24  1     DR    0/0
Vl28         1     72              172.21.100.254/24  1     DOWN  0/0
Fa0/12       1     72              172.21.111.5/30    1     BDR   1/1
Yes , 172.21.111.2 will be the source of the icmp packets generated from Rtr-Clake.
From your first output Rtr-Clake :
show ip route
C       172.21.111.0/30 is directly connected, FastEthernet0
C       172.21.98.128/26 is directly connected, Vlan62
Running config
interface Vlan1
interface Vlan61
interface Vlan62
There are some connected vlans missing. Which one is your current config ?
- Could you check the router 172.19.254.66 for the 172.21.111.0/30
- Paste please the output for your Rtr-Clake : ping 10.218.34.5
Dan
Dan,
This is the current config.
hostname Rtr-ClakeTelem-01
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0
ip address 172.21.111.2 255.255.255.252
duplex auto
speed auto
interface Vlan1
interface Vlan61
interface Vlan62
router ospf 1
area 66 stub
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tacacs source-interface FastEthernet0
tacacs-server host 10.218.34.5
tacacs-server directed-request
tacacs-server key 50ftw4r3
tacacs-server administration
control-plane
Ping ping 10.218.34.5 doesnt work from this rtr
Kevin
