not able to configure EtherChannel on
att-sgcops
I tried to configure EthernChannel on Cat2948 L3 switch, but failed. Not sure it is because of the limitation of the paltform or configuration problem, I post the "show version" and "show config" here:
sw#sh ver
IOS (tm) L3 Switch/Router Software (CAT2948G-IN-M), Version 12.0(25)W5(27b) RELEASE SOFTWARE
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 11-May-04 18:45 by integ
Image text-base: 0x60010928, data-base: 0x6060A000
ROM: System Bootstrap, Version 12.0(7)W5(15) RELEASE SOFTWARE
sw-sgdc-3rdflr uptime is 1 year, 27 weeks, 5 days, 7 hours, 31 minutes
System restarted by power-on at 02:31:36 UTC Fri Nov 26 2004
System image file is "bootflash:cat2948g-in-mz.120-25.W5.27b.bin"
cisco Cat2948G (R5000) processor with 49152K/16384K bytes of memory.
R5000 processor, Implementation 35, Revision 2.1
show config (configuration is the same for all the interface):
interface FastEthernet1
no ip address
no ip directed-broadcast
bridge-group 1
interface BVI1
ip address 10.10.10.1 255.255.255.0
And if i want to add 1 more connection to implement load-sharing, how to do that?
5 Replies 5
vladrac-ccna
Level 5
Level 5
Just curious, do you really need bridging in this network?
your post title states etherchannel ?
where are these configs?
anyway check the following link for etherchannel configs for CAT2948
http://www.cisco.com/warp/public/473/172.html#configs
HTH,
if it does please rate this post.
vlad
is it because of the bridging, that i am not able to config EtherChannel? It was configured by someone else and I don't want to change that. there are only 1 vlan on that.
when confiugrin make sure that your all port should have same characteristics like duplex speed and i think your all ports should be in the same VLAN. so first of all check it out that.
rate this post if it helps
regards
Devang
there's no problem to put bridge-group on your configuration.
Please take a look on the link I've posted, you'll see etherchannel using bridge-group.
But again, could you give us the complete etherchannel configuration?
to have etherchannel running you need similar configs in all the interfaces under the same channel-group (in both switches), assuming that you are using a etherchannel to link 2 switches together.
Please give us more information about your actual problem and configs.
and dont forget to rate any helpful posts (grades range from 1 to 5 - from not helpful to really helpful).
Vlad
"!--- Configure a logical interface for the EtherChannel.
interface Port-channel1
no ip address
hold-queue 300 in
!--- Create a subinterface for each VLAN on the port channel.
interface Port-channel1.1
!--- Specify the encapsulation and VLAN number.
encapsulation dot1Q 1
no ip redirects
!--- Add the subinterface to the appropriate bridge group.
!--- All the interfaces (and subinterfaces) that belong to the
!--- same VLAN (network or subnet) should be configured to fall
!--- in the same bridge group.
bridge-group 1
!--- Configure a subinterface for the second VLAN.
!--- This procedure must be repeated for every VLAN.
interface Port-channel1.2
encapsulation dot1Q 2
no ip redirects
bridge-group 2
!--- Configure a subinterface for the native VLAN.
interface Port-channel1.99
encapsulation dot1Q 99 native
no ip redirects
!--- Note in this case you do not put any bridge group
!--- statements under this subinterface. A dummy VLAN has been chosen
!--- as the native VLAN on which you do not put any traffic,
!--- so there is no need to have this routed.
no ip address
!--- Configure the port to channel 1.
channel-group 1
interface FastEthernet2
no ip address
channel-group 1
interface FastEthernet3
no ip address
!--- The device connected on this interface belongs
!--- to the same subnet (VLAN 1) as subinterface 1 on
!--- the port channel, so this interface has to be added to
!--- bridge-group 1.
bridge-group 1
!--- If there are any other interfaces that belong to
!--- the same VLAN (subnet), they all have to be added to
!--- the respective bridge group.
( .... Output is suppressed)
! a routed interface for bridge-group 1
interface BVI1
ip address 1.1.1.1 255.255.255.0
no ip route-cache cef
! a routed interface for bridge-group 2
interface BVI2
ip address 2.2.2.1 255.255.255.0
Roberto Salazar
Level 8
Level 8
Usually, when you channel two or more interfaces, is because you are connecting those interface to another switch. With your example above, it looks like you have a fastethernet that you might be connecting to a host, channeling will not work and it's not for that purpose, if however, I am wrong with my assumption, the following link should help you configure it:
http://www.cisco.com/univercd/cc/td/doc/product/l3sw/2948g-l3/rel_12_0/7wx515a/config_g/ether_ch.htm
Remember this is a router/bridge device not a switch like Cat2948G or Cat4000.
Please rate helpful post.
