Not able to ping / route to different network
renyadoor
I configured two router one router is connect to internet (config which i showed below) from that router I can able to ping google or any website. that is going through ip 10.31.72.41 and another one router (network) is connected to this router with MPLS line that network is connected to G0/1 (192.168.0.2) on that router have another one local network 10.31.74.0 is connected.
R1
GEth 0/0 - 10.31.72.41                              R1 having internet on GEth 0/0
GEth 0/1 -  192.168.0.2
R2
GEth 0/0 - 10.31.74.55
GEth 0/1 - 192.168.0.10
both these router is connected via MPLS line and R2 need to get internet from R1.
when I trying to ping 10.31.72.41 from R2 its pinging and trying to ping 10.31.74.55 from R1 also pinging.
but when I'm trying to ping 10.31.72.250 from R2 is not pinging and showing request timed out. 10.31.72.250 is the IP which providing internet and that link is connected 10.31.72.41
and when i'm trying to ping 10.31.74.1 from R1 is not pinging and showing request timed out
both router have Gigabyte Ethernet
and its connected to Fast ethernet is there any problem with that? Can you please guide me any problem is there in the configuration, or connection. I didn't understand. Please help. Thank you in advance.
Current configuration : 1541 bytes
! Last configuration change at 09:43:39 UTC Wed Aug 1 2012
! NVRAM config last updated at 09:00:01 UTC Wed Aug 1 2012
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip name-server 195.229.241.222
ip name-server 213.42.20.20
license udi pid CISCO1941/K9 sn FCZ161190K5
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.31.72.41 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.0.2 255.255.255.252
ip ospf network point-to-point
duplex auto
speed auto
router ospf 91
redistribute connected
network 10.31.0.0 0.0.255.255 area 0
network 192.168.0.0 0.0.0.3 area 0
network 192.168.0.8 0.0.0.3 area 0
ip default-gateway 10.31.72.250
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.31.72.250
ip route 10.31.74.0 255.255.255.0 192.168.0.9
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
router ospf 91
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
end
Router#
Hi Renyadoor,
i guess you need a redistribute static below your OSPF process. By the way you can check this on your routing table.
Don't forget the keyword subnet... It could be helpful in the future for a different garnularity and route control.
Alessio
Dear Alessio,
Thank you very much for quick response.
I tried to put redistribute, but its showing "only classful networks will be redistributed" i don't know this is correct or not. please guide me to put redistribute....for static to ospf
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#router ospf 91
Router(config-router)#re
Router(config-router)#redistribute sta
Router(config-router)#redistribute static metr
Router(config-router)#redistribute static metric 2
% Only classful networks will be redistributed
Hi Renyadoor,
this is the correct natural behavior of this kind of redistribution ... unless using the keyword subnet:
redistribute static subnet
Try and let me know
Alessio
