11-30-2011 03:45 PM - edited 03-04-2019 02:28 PM
Hello
I have a problem where I don't receive RIP Updates from upstream devices 192.168.x.20 and 192.168.x.21. This is on a 3750 L2 Switch with IOS c3750-ipservices-mz.122-25.SEB4. RIP only seems to be Sent/Recieved on one Interface (VLAN 4). Basic config, debugging and show output below.
interface Vlan2
ip address 192.168.x.1 255.255.255.128
interface Vlan3
ip address 192.168.x.129 255.255.255.128
interface Vlan4
ip address 10.111.x.252 255.255.255.240
router rip
version 2
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.111.x.254
ip route 10.11.x.0 255.255.254.0 192.168.x.124
ip route 10.x.165.0 255.255.255.224 192.168.x.20
ip route 10.x.11.0 255.255.255.0 192.168.118.124
ip route 10.x.23.0 255.255.255.0 192.168.118.124
ip route 10.111.0.0 255.255.0.0 192.168.118.20
ip route 10.254.0.0 255.255.240.0 192.168.x.20
debug ip rip
1y6w: RIP: sending v2 update to 224.0.0.9 via Vlan4 (10.111.254.252)
1y6w: RIP: build update entries - suppressing null update
sho ip rip database
10.0.0.0/8 auto-summary
10.111.x.240/28 directly connected, Vlan4
sho ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 27 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Redistributing: rip
Default version control: send version 2, receive version 2
Interface Send Recv Triggered RIP Key-chain
Vlan4 2 2
Automatic network summarization is in effect
Maximum path: 4
Routing for Networks:
10.0.0.0
Routing Information Sources:
Gateway Distance Last Update
Distance: (default is 120)
Solved! Go to Solution.
11-30-2011 05:00 PM
You need to configure VLAN2 and VLAN3 for RIP routing.
If you look under 'show ip protocols' you will see that the router is only routing for the 10.0.0.0 network with RIP.
I would also do a 'no auto-summary' as well.
router rip
network 192.168.x.0
network 192.168.x.128
11-30-2011 05:00 PM
router rip
network 192.168.x.0
