nsf
stephtchoko
Level 3
Level 3
please,
when to use nsf in the network which use eigrp ?
regards.
pkhatri
Level 11
Level 11
NSF is a feature primarily designed for networks with high availability. Therefore, if you are designing a network for high availability, then NSF is an option. You have to, of course, use equipment that is NSF-capable....
Hope that helps - pls rate the post if it does.
Paresh
please,
how does it bring high availability in the network.
Regards.
High availability is exactly what the feature is designed for.
Paresh
