object tracking in 12.4.9T1
wildker-vit
Hi!
Could you tell me which command should be used instead of
"track 50 rtr 50 reachibility "
when I use Cisco IOS Software, 1841 Software (C1841-IPBASEK9-M), Version 12.4(9)T1?
tdrais
Level 7
Level 7
They have changed this so much that I don't remember which parts are supported in IPBASE. Most the feature like this are only supported in advanced ip services.
Kinda expensive to upgrade the software just to get this option.
