on multilink interface ip load sharing per-packet is not available on 7609
sgopikrishnan
7609(config)# int mul 11
7609(config-if)#ip load-sharing
7609(config-if)#ip load-sharing ?
per-destination Deterministic distribution
7609-2(config-if)#ip load-sharing
> The card is STM1/OC3 with SFP modules in it
> dCEF is enabled,
> is there any hidden command or any software bug, i am using 12.2(33)SRA5 or suggest IOS which supports this
the following command is also not available
Globalconfig#hw-module slot <no> per-packet
it is very urgent kindly help me out
Peter010101
ip load-sharing is used under the physical interface.
With a multi link you are already load sharing with the circuits that are bundled.
the same is working fine(on Multilink) in 7206 router. But
the physical interface on 7609 also is displaying the same (per-packet is not seen)
