One command for IP addresses and descriptions
sebastian.lemke
Hello all,
most of us use the following commands very often:
"show ip interface brief"
"show interface description"
Is there any command, which show interface IP addresses and descriptions?
Can I combine these commands somehow?
Jennifer Halim
This command might be something you are looking for:
sh interface | i line protocol|Internet address|Description
Hope that helps.
Jennifer Halim
Hope that helps.
ahh, that's it, thanks a lot!
It's not as neat as the output of the other commands, but it works.
I didn't know, that you can combine the "| include" filters... Do you have a website, where this is documented?
I don't think we have a documentation that includes that specifically, however, I believe it uses the normal regular expression symbols for multiple matches.
