One Network, Three Routers
alephpp
Hi, I'm a bit new to Cisco, I'd like to know if this is possible
This was presented by my teacher and he explain that in theory this is possible, but I know he likes to play tricks so I'm a bit skeptical on that. Is there any way this is possible? Thanks!
2 Accepted Solutions
M02@rt37
Hello @alephpp,
Router R1 cannot have two interfaces in the same subnet --- not possible!
You could use VRF as @DanielP211 proposed.
Best regards
It's possible. As long as the middle router has the interfaces in two seperate VRF's there is no issue here, and I assume the IP's from the subnet are different.
BR
****Kindly rate all useful posts*****
9 Replies 9
DanielP211
What is the question here? If the same segment can be assigned to two different interfaces of a switch? It can if you are using VRF's.
BR
Hi there,
The question that is presented is if it's possible to have the same network segment across three routers? As far as I know, they'll just overlaps.
Thanks for replying!
BR
M02@rt37
Hello @alephpp,
Best regards
alephpp
Thanks for helping, y'all!
You're very welcome.
Best regards
Joseph W. Doherty
Well, it depends what your "tricky" teacher has in mind.
What M02@rt37 suggests might be done but if you want to exchange traffic between
R0 and R1,
it gets "complex".
What teacher might have in mind, on
R2 is IRB.
  (What's that?  Student exercise - look it up.)
Hello @alephpp ,
I think that @Joseph W. Doherty is right here the teacher is presenting a possibile use case for
IRB
or at least on the possibility to configure the router in the middle to bridge between two interfaces.
With
IRB
Integrated Routing and bridging a L3 interface can also be associated to the bridge domain and would make the router in the middle able to speak IP in the common subnet.
to be noted in more modern
IOS XE IRB is configured using BDI
instead of BVI as L3 interfaces.
This is more a change in syntax of commands but from conceptual point of view it is still
IRB.
Solutions using VRFs would probably be an overkilling tool and also would require addition of NAT to work as the subnet would be overlapping.
Hope to help
Giuseppe
"Solutions using VRFs would probably be an overkilling tool and also would require addition of NAT to work as the subnet would be overlapping."
Yea, part of the complexity of a VRF solution, two way NAT.  Although, you can use the whole
/24 address
space on both sides.
Again, though, doable with VRFs.
I've also wondering whether something like
L2TPv3
might be used with, or without, VRFs to join the two segments at L2.  Much would depend whether want R2 to also have an address in that
/24.
