one-time password in ISR 2911
rooland12
Hello  everyone, I've got similar problem,I logged in first time with default  user ID and Password i.e.,cisco then I did wr erase and reloaded the  router but I  didn't change the one-time password in ISR 2911.Now its  asking for user name and passworkd and cisco doesn't work.Now from  ROMMON mode if I change to 0*2142 and reset it will again come back to  ROMMON mode.From ROMMON mode if  I type boot will come back to normal mode and ask for username and password. so I'd be very grateful if anyone can help me.
Thanks.
2 Accepted Solutions
Peter Paluch
The password recovery on 2911 series should  prevent the router from asking you any password. If it is not effective  then I am afraid you have not performed it correctly. Please follow the  instructions in the following document very closely
http://www.cisco.com/en/US/products/ps5854/products_password_recovery09186a0080b34901.shtml
Especially, the confreg command shall be input as confreg 0x2142, not confreg 0*2142 as you indicated in your original post.
Best regards,
Peter
Yes, that is most probably the cause. The 'x' sign in the 0x2142 does not stand for multiplication but rather signifies that the number is given in hexadecimal, and must be written as literal 'x'.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
Hi Peter,
Thanks for the response. I guess I gave the input wrong as I was giving confreg 0*2142. As you suggested will try with confreg 0x2142 on Monday.
I will update you if I'm successful.
Best regards,
Peter
Heloo Peter,
0x2142 did the magic....Thanks once again. I used to think "x" stands for multiplication that's why was trying with " * ".
Rooland
