one vlan can connect but other cannot connect to dhcp server
2005074F93956
My vlan for 401 cant works but from vlan 301 can from the dhcp server
you need to add subinterfaces for Vlan 301 and Vlan 401 on the Paris router. I have also added Vlan 80 as the management Vlan for the switches. In addition, you need some sort of routing protocol between your routers, I have configured EIGRP. Review the attached file, which provides end-to-end connectivity...
Mark Elsen
 - If the DHCP server is no longer on the same local subnet , then you may need a helper address for the particular vlan:
   https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp/command/iap-cr-book/iap-i1.html#wp1413119578
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
the code still does not work and my ip addressing is from server not router
i use the code u and i did rip and encaps alr . now the dhcp server cant access all the vlan
