Port Forwarding without inter vlan routing.
emaid
Hi all.
I have Cisco RV260W with 3 vlans configured:
Vlan 1 : 192.168.10.0 (used for team)
Vlan 2: 192.168.20.0 (used for public wifi (investor comming visiting us etc..., no need to acces internal network) )
Vlan 3: 192.168.30.0 (used for external partners with specific machines inside)
I have disabled inter vlan routing because I want vlan isolation.
I have a VPN server on VLAN1 with port forwarding on it.
Since I disabled inter-vlan-routing on Vlan1...impossible to acces to OpenVPN for all clients.
If I enable it it's ok but vlan1,2 and 3 can communicate and I don't whant that...
Do you have some idea ?
Is it something about routing ?
Thanks a lot :)
Hello
You can append a routered access-list to the L3 interfaces to negate access between the vlans or you could put each vlan in an spearate vrf, However having ever worked on that particaulr rtr I would say the former option would be the most viable option if indeed it is applicable.
See attached file:
Kind Regards
Paul
Hello
See attached file:
Kind Regards
Paul
Thanks a lot ! working perfect with acces list !
