One way communication over Checkpoint to PIX VPN
v-koul
I have created a VPN between the checkpoint & PIX but only one way communication is taking place.
From PIX can ping and access required devices on Checkpoint side but other way round nothing is happening.
I am using Nat on PIX because there was super netting problem earlier.
Any help regarding this is appreciated.
Vishal
itindia
Hi Vishal,
Few quick suggestions:
1. See the VPN traffic is not natted on checkpoint side.You need to place the rule on the top after stealth rule.
2.See under global properties if you are using NG with AI regarding Enable decryption on Accpet is cheked if not then it will never encrypt the packet.In that case need to allow encrypting domains using accept action first.
Hope this will help you.
Reg,
Sushil
