05-25-2017 11:41 AM - edited 03-05-2019 08:36 AM
I have a RV180 that I want to open the firewall, both incoming and outgoing for one IP Address. The IP address is a reserved address, assigned by MAC address for a AT&T microcell.
The RV180 is connected to Cox Cable modem. The cable modem is in bridge/passthrough mode.
On the Inbound rule, I can't specify the LAN IP address. On the Outbound rule It appears i can set both IP addresses.
What am I missing?
Thanks.
Len
Solved! Go to Solution.
05-25-2017 01:25 PM
for the inbound rule, you have to use the 'Send to Local Server (DNAT IP) field to specify the LAN address. Check page 82 (Step 7) of the attached admin guide:
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv180w/administration/guide/rv180w_admin.pdf
05-25-2017 01:25 PM
05-26-2017 07:33 AM
Georg,
Thanks for the response.
I thought that was the place for the address, but I wasn't sure. Thanks for confirming it for me.
Len
