Opinion choice cisco
pierrea33
I allow myself to write to you because we have in the company where I work routers that we would like to change to cisco products.
In particular, we saw the
cisco n9k-c93180yc-fx
what do you think ?
We need a router that supports at least two full tables and the prefixes that we retrieve on different IX (2 in total).
This one may seem right to me, I also saw an
NCS-5501
how many prefixes can it support ?
Thank you in advance and have a good day,
Pierre
2 Accepted Solutions
@pierrea33,
Number of prefix depend of the equipment/IOS etc etc
What is your current router model ?
here the portfolio Cisco Router with their role:
https://www.cisco.com/c/en/us/products/routers/product-listing.html
Best regards
Flowace
Choosing the right router for your company's needs is an important decision, and I'll be glad to provide some insights on the
Cisco N9K-C93180YC-FX
and
NCS-5501
models.
  1. Cisco N9K-C93180YC-FX:
    • The
      is a fixed-configuration, data center switch designed for high-performance and low-latency networking environments.
    • It is part of the
      Cisco Nexus 9300 series
      which is optimized for
      1/10/25/40/50/100 Gigabit Ethernet
      deployments.
    • The
      N9K-C93180YC-FX
      is known for its versatility and scalability, offering support for both Layer 2 and Layer 3 features.
    • It can handle large amounts of traffic and is well-suited for data center deployments and spine-leaf architectures.
    • Regarding routing capabilities, the
      N9K-C93180YC-FX
      can support two full tables and handle BGP routing with the prefixes obtained from different Internet Exchanges (IX).
  2. Cisco NCS-5501:
    • The
      Cisco NCS-5501
      is a member of the Cisco Network Convergence System (NCS) series, designed for service provider core and aggregation networks.
    • It is optimized for high-performance, highly scalable, and carrier-grade deployments.
    • The
      NCS-5501
      supports various interfaces, including
      10/25/40/100 Gigabit Ethernet.
    • For routing capabilities, the
      NCS-5501
      can handle a large number of prefixes. The specific capacity depends on factors like the amount of memory and software configuration. With appropriate memory and software licensing, it can support multiple full BGP tables.
When choosing between these two routers, consider the specific needs and requirements of your network environment. The
is more focused on data center deployments and may be a suitable choice if you primarily require high-performance switching capabilities with some routing features.
On the other hand, the
Cisco NCS-5501
is designed for carrier-grade deployments and can handle a significant number of BGP prefixes, making it a good fit for service provider networks or large-scale deployments requiring extensive routing capabilities.
To make an informed decision, it is essential to evaluate the specific use case, scalability needs, and future growth expectations of your network. Additionally, consider factors like software licensing, support, and any other additional features required for your environment.
I recommend reaching out to Cisco or an authorized Cisco reseller for more detailed information on each product's capabilities and their suitability for your company's specific network requirements.
As always, consult with networking professionals or specialists who can assess your network's exact needs and help you select the most appropriate solution. I hope this information helps you in making the right choice for your company's network infrastructure. Have a great day!
13 Replies 13
M02@rt37
Hello @pierrea33,
Cisco Nexus series switches, including the
Nexus 9300
series to which the
belongs, are primarily designed for data center LAN (Local Area Network) deployments rather than serving as traditional routers for routing traffic between different networks.
The Nexus switches are often used in data center
top-of-rack or end-of-row
deployments to provide high-performance, low-latency, and high-density switching for servers and storage within the data center network. They are optimized for data center environments and offer features like Virtual Port Channels , VXLAN (Virtual Extensible LAN) to address the specific needs of modern data centers.
While Nexus switches have some L3 capabilities, such as static routing and basic IP routing, they are not typically used as primary routers for managing complex routing tasks, especially handling full BGP routing tables from multiple Internet Exchanges. Instead, for such routing-intensive scenarios, Cisco's routing-focused products like the Cisco NCS series routers, including the
NCS-5501
are more suitable.
What have you got now as routers?
Maximum number of supported prefixes can vary based on the specific use case and the amount of available memory. You mean full table Internet ?
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-5500-series/ncs-5500-5700-platform-ar-wp.html
Best regards
Hello M02@rt37,
Thank you for your answer.
Currently we have
Arista 7280SR3-48YC8
The
cisco N9K
evoke before seemed to me to be a good understanding because we are looking for distribution but also to do L3, when I was talking about maximum prefix, I meant by that the number of times that can support the routing table with BGP, knowing that a full table is about
900k of prefix,
I would need at least
1800k to see 2000k
Can an NCS have an amount of evolutive ram ? How does it go ?
Have a good day,
Pierre
Hi @pierrea33
 Nexus is not a router and
NCS-5000
is end of sale.
Look for
ISR4331
or, depending on the nework size,
ASR9K
Hi @Flavio Miranda,
Thank you for the answer but an ISR is not suitable for what I am looking for, what variant of the
N9K ?
 @pierrea33,
you need routing?  go to
ASR9k or NCS5XX
Best regards
M02@rt37,
Thank you for your response.
Okay, Do you have a model to advise me that would hold
2000k-2500k
of prefix ?
@pierrea33,
Best regards
Flowace
and
NCS-5501
models.
    • The
    • It is part of the
      deployments.
    • The
      N9K-C93180YC-FX
      N9K-C93180YC-FX
  2. Cisco NCS-5501:
    • The
      Cisco NCS-5501
    • The
      NCS-5501
      NCS-5501
Cisco NCS-5501
Thank you for your message I will study this !
okay
r.heitmann
Nexus 93180yc
is an uncommon solution for an internet-access-router, but - of course it can act as high-performance
IP-Router, routing-tables for IPv4/v6
might be large enough for todays requirements:
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-742284.html
Item
Cisco Nexus 9300-FX Series Switches
Maximum number of IPv4 Longest Prefix Match (LPM) routes**
1,792,000
Maximum number of IPv6 Longest Prefix Match (LPM) routes**
896,000
How long do you want to use this device before it will be replaced? 3 years, 5 years?
As others mentioned:
  • a device "designed as a router" might be more flexible regarding routing-table size.
  • former "ISR"-Routers are called "Catalyst" today:
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/datasheet-c78-744088.html
