OSPF and Palo alto firewall
TRACY HARTMANN
Our security department is switching from a Checkpoint configuration to a Palo Alto firewall.
We run OSPF between our cisco routers and the checkpoint today.   The Palo Alto takes over the same IP address and has the ospf password.
When I do a show ip OSPF neighbor I see the checkpoint, when we moved to the Palo Alto I didn't even see it trying.   However the traffic seemed to work fine.   Do I have to configure the OSPF any different for the Palo Alto ?
Thank
gerardothink
if you execute a debug ip ospf, Do you see any ospf errors?
also I am assuming you are using different router-id for each, correct?
Richard Burts
You ask this question " Do I have to configure the OSPF any different for the Palo Alto". We do not know how the Checkpoint was configured. So we do not know if there was anything unique in its configuration. So it is difficult to know if Palo Alto needs anything unique in its configuration of OSPF. If traffic seems to be working fine that is a fairly good indicator that the OSPF configuration is ok.
Rick
Rick
