OSPF AREA IS SHOWING 2 WHEN I HAVE CONFIGURED ONLY 1 AREA IN ROUTER
Farhan64
Router#sh ip protocols
Routing Protocol is "ospf 1"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Router ID 4.4.4.4
Number of areas in this router is 2. 2 normal 0 stub 0 nssa
Maximum path: 4
Routing for Networks:
192.168.24.0 0.0.0.255 area 66
192.168.34.0 0.0.0.255 area 66
192.168.45.0 0.0.0.255 area 66
Routing Information Sources:
Gateway Distance Last Update
2.2.2.2 110 00:07:51
3.3.3.3 110 00:07:51
4.4.4.4 110 00:45:28
5.5.5.5 110 00:07:55
Distance: (default is 110)
RUNNING CONFIGURATION
Router#SH RUN
Building configuration...
Current configuration : 1053 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15243909-
no ip domain-lookup
spanning-tree mode pvst
interface Loopback0
ip address 4.4.4.4 255.255.255.0
interface GigabitEthernet0/0
ip address 192.168.45.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
ip address 192.168.24.2 255.255.255.0
clock rate 64000
interface Serial0/1/1
ip address 192.168.34.2 255.255.255.0
clock rate 64000
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 4.4.4.4
log-adjacency-changes
network 192.168.24.0 0.0.0.255 area 66
network 192.168.34.0 0.0.0.255 area 66
network 192.168.45.0 0.0.0.255 area 66
ip classless
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
Router#
OSPF NEIGHBOUR
Router#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
5.5.5.5 1 FULL/DR 00:00:38 192.168.45.2 GigabitEthernet0/0
3.3.3.3 0 FULL/ - 00:00:38 192.168.34.1 Serial0/1/1
2.2.2.2 0 FULL/ - 00:00:38 192.168.24.1 Serial0/1/0
Router#
is this a 2901 router in Packet Tracer ? Post the zipped .pkt file. It could also just be a bug in Packet Tracer...
6 Replies 6
Christopher Hart
Hello!
Can you clarify what specific version of IOS 15.1 you're running on this 1941 router? It might be a result of a known defect CSCsy28636.
Thank you!
-Christopher
Router1>sh version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 23-Feb-11 14:19 by pt_team
USING LATEST PACKET TRACER
Martin L
it is probably a bug in IOS or PT software sim; glitch; or left over from other ospf configs that have been removed;  Try clear ip osp process to see if that goes away.
I assumed this is router 4 on the picture, right?
Regards, ML
**Please Rate All Helpful Responses **
Perhaps the output of show ip ospf might be helpful. I agree that it sounds like there might have been a different ospf area configured and then removed. So I agree that clearing the ospf process might be helpful.
Rick
Yes, I think it was a bug, in morning it automatically says display as
"Number of areas in this router is 1"
Router ID 4.4.4.4
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
Maximum path: 4
2.2.2.2 110 00:16:49
3.3.3.3 110 00:12:21
4.4.4.4 110 00:16:21
5.5.5.5 110 00:12:06
