OSPF area range
feiyang
Hello expert,
I am trying to configure an ospf area range to summarize the routes in area 1:
1.1.8.0/24, 1.1.9.0/24, 1.1.10.0/24, 1.1.11.0/24
by using area 1 range 1.1.8.0 255.255.252.0
However, on the other ospf routers in area 0, I can see the summary route 1.1.8.0/22, and also the four /24 routes.
I am using 12.4 image, do I miss anything?
Thanks.
pkhatri
Level 11
Level 11
How many ABRs do you have between area 0 and area 1 ? If you only configure the
area range
command on one of the ABRs, then the other ABRs will still advertise the /24s.
Paresh
PS. Pls do remember to rate posts.
pkhatri
Level 11
Level 11
area range
Paresh
amit-singh
Level 11
Level 11
I think You have done the things correctly. is this configuration done on the router once it alredy had the above listed /24 routes in the database.
Is this a test setup. try clearing the routes manually and check if the router still lists them.
clear ip route
-amit singh
