ospf config
anitachoi3
below is my ospf setting,
router ospf 100
network 192.168.1.0 0.0.0.255 area 0
network 172.16.1.5 0.0.0.3 area 1
what is different if I change to
"network 172.16.1.4 0.0.0.3 area 1"
which one is better?
or
rdgs
2 Accepted Solutions
Jon Marshall
Anita
Generally it would be either
network 172.16.1.5 0.0.0.0 area 1
OR
The mask just allows you to be very specific about which interfaces to run OSPF on.
As to which is better, well in this case it doesn't make a lot of difference because 172.16.1.4 0.0.0.3 only covers 172.16.1.4 -> 172.16.1.7.
Jon
Anita
It should be the same result.
I believe that you can type it in as:
but when you do show run I believe that you will find that IOS has translated and it will show up as:
This is because the address you want to input and the mask are inconsistent. The mask of 0.0.0.3 indicates a subnet address with mask of 255.255.255.252 and IOS will translate what you input to show the subnet address if you use the "subnet" nask.
Rick
Rick
Jon Marshall
Anita
OR
Jon
can I config as
Is it the same result?
rdgs
Anita
Rick
Rick
