OSPF default interface
Steph1963
Hello to All
I have found the following info this link http://www.cisco.com/en/US/docs/ios/12_0t/12_0t2/feature/guide/defint.html
Network managers may not always be able summarize type-5 link-state advertisements (LSAs) at the router level where redistribution occurs, as in the first possibility. Thus, a large number of type-5 LSAs can be flooded over the domain.
Question 1): Does that means that OSPF would redistributed connected interface as type 5 LSA and this type cannot be summarized while going through another area (I think that type 5 in area 1 will remain type 5 in area 0)
In the second possibility, large type-1 link-state LSAs might be flooded into the area. The area border router (ABR) creates type-3 LSAs, one for each type-1 LSAs, and floods them to the backbone. It is possible, however, to have unique summarization at the ABR level, which will inject just one summary route into the backbone, thereby reducing processing overhead.
Question 2) Doest that means using OSPF passive interface that will used type 1 LSA ant that type 1 LSA can be summarized at the Area Border Router
In the following network, does somebody knows why the OSPF database does not show any LSA entry for the 172.31.129.0 network on R3 router while LSA entry are present on R1 router.
R3#show ip ospf database
            OSPF Router with ID (3.3.3.3) (Process ID 10)
                Router Link States (Area 1)
Link ID         ADV Router      Age         Seq#       Checksum Link count
1.1.1.1         1.1.1.1         476         0x80000002 0x00D732 1
3.3.3.3         3.3.3.3         475         0x80000002 0x0054CD 4
                Net Link States (Area 1)
10.0.0.6        3.3.3.3         475         0x80000001 0x000D04
                Summary Net Link States (Area 1)
1.1.1.1         1.1.1.1         516         0x80000001 0x0047EC
2.2.2.2         1.1.1.1         467         0x80000001 0x00230C
11.0.0.0        1.1.1.1         267         0x80000004 0x00DF4A
R1#show ip ospf database
OSPF Router with ID (1.1.1.1) (Process ID 10)
                Router Link States (Area 0)
1.1.1.1         1.1.1.1         446
2.2.2.2         2.2.2.2         446
                Net Link States (Area 0)
11.0.0.2        2.2.2.2         447
                Summary Net Link States (Area 0)
3.3.3.3         1.1.1.1         431
10.0.0.4        1.1.1.1         426
172.31.129.0    1.1.1.1         431
1.1.1.1         1.1.1.1         441
3.3.3.3         3.3.3.3         442
10.0.0.6        3.3.3.3         443
1.1.1.1         1.1.1.1         482
2.2.2.2         1.1.1.1         432
11.0.0.0        1.1.1.1         232
Router 3 configuration:
R3 Configuration
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0/0
ip address 10.0.0.6 255.255.255.252
duplex auto
speed auto
interface FastEthernet1/0
ip address 172.31.129.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet2/0
ip address 172.31.129.5 255.255.255.252
duplex auto
speed auto
router ospf 10
log-adjacency-changes
passive-interface FastEthernet1/0
passive-interface FastEthernet2/0
network 3.3.3.3 0.0.0.0 area 1
network 10.0.0.4 0.0.0.3 area 1
network 172.31.129.0 0.0.0.255 area 1
Router 1 Configuration
R1 Configuration
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 10.0.0.5 255.255.255.252
duplex auto
speed auto
ip address 11.0.0.1 255.255.255.252
duplex auto
speed auto
router ospf 10
router-id 1.1.1.1
area 0 range 11.0.0.0 255.0.0.0
area 1 range 172.31.129.0 255.255.255.0
network 1.1.1.1 0.0.0.0 area 0
network 11.0.0.0 0.0.0.3 area 0
Thanks for your help
Stéphane
Is there a way of summarizing RIP or EIGRP redistributed route into OSPF across another area with the area range XX command or with any other command.
The command to summarize at ASBR is summary- address (under router ospf config)
2)
I do not know what is the difference between using passive-interface and redistribute connected
Passive-interface in OSPF(as in EIGRP) means no neighbour relationship anymore
redistribute connected means to redistribute into OSPF process the directly connected routes already in the rib.
So these 2 features have no relationship whatsoever.
3)
as far as I know lsa type1 is router lsa and so sh ip ospf database router will only show this lsa type but if you see them here then
   you'll see them in the output of sh ip ospf database as well
Regards.
Alain.
cadet alain
You can summarize at the ASBR or ABR, these are the only 2 points in the network where you can do it  with OSPF and all redistributed routes
are E2 routes by default.
Passive interface in OSPF breaks the neighbour relationship
on R1 you summarized at ABR and that's what appears but are you sure your 2 interfaces on R3 going to hosts are in the OSPF process?
---> sh ip ospf interface brief or sh ip ospf interface f1/0 and sh ip cospf interface f2/0 will tell you
Regards.
Alain.
Hi Alain,
Thanks for your response,
1) I was under the impression that E2 routes (Type 5 LSA) could not be summarized at the ABR or ASBR based on the following paragraph:
I am not too sure how OSPF can summarized redistributed rip (or any other routing protocol) directly at the ASBR. Is there a way of summarizing RIP or EIGRP redistributed route into OSPF across another area with the area range XX command or with any other command.
2) Using passive-interface or redistribute connected seems to generate same LSA-type 1 (Router) and these ones seems to summarizable with the OSPF area range XX comand. I do not know what is the difference between using passive-interface and redistribute connected.
3) I was able to found that 172.31.129.0 and 172.31.129.4 are defined as LSA-type 1 stub network and are shown under show ip ospf database router but not under show ip ospf database, do not know why.
Stephane
1)
2)
3)
Regards.
Alain.
Makes a lot of sense.
Stephane
