Problem with l2tp in a Cisco 1921
miguelpinto
I'm having a problem when configuring this cisco router 1921 with an ip base software. Accordingly with the Cisco software advisor this sotware allows to configure the l2tp Client Initiated  Tunneling.
But configuring the router the commands are not recognized:
Router(config)#pseudowire-class L2TP_PSEUDO
% Invalid input detected at '^' marker.
Router(config)#interface Virtual-PPP1.
Can you help me discovering this big issue. Is it a problem of software, or release.??
Looking forward for your cooperation.
Best Regards,
MiguelPinto
kmccourt
I have a 1921 with ip base, data and sec licenses running IOS 15.1(3)T. The command is available on this router:
Cisco-1921#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Cisco-1921(config)#ps?
pseudowire-class
Check the Cisco Feature Navigator at http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
I suspect you'll find you need an additional license, probably data, for this to work.
