OSPF Design Help
kevin.hu
Level 3
Level 3
Please refer to my simple diagram.
Network 1 reaches Network 3, 4 and unknown networks via link 1 only. If link 1 fails, it should use Link 2 as the back up link. The same applies to Network 2. Network 2 should only use Link 2. How do I design my OSPF according to these requirements? Thanks.
mohammedmahmoud
Level 11
Level 11
I guess that your design has fulfilled your needs as OSPF prefers intra-area over inter-area routes, and thus network 1 will always prefer link 1 and link 2 would be its backup and vice versa.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
How would traffic from network 1 come back if I only advertise network 1 from area 1 in case link 1 fails?
