OSPF en routers Cisco modelos 881
IntecAsociados
Los routers vienen con este software de acuerdo al Show version, pero no tienen habilitado el protocolo OSPF.
"Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 29-Oct-10 00:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Quisiera saber como hacer para habilitarlo.
Desde ya muchas gracias por su colaboración
A/S Daniel Ceriani
hbruyere
The universal image contains all the features sets, but you need to activate the "advipservices" package to be able to configure OSPF.
You can enable an evaluation licence for advipservices with the following command:
license boot module c880-data level advipservices
... then reboot the router.
More informations about licences here:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
Herve
I disagree with your response.  I have an 881 router running IOS 15.1(3)T and I can't get OSPFv2 enabled.
I have "advipserves " enabled.
License Information for 'c880-data'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
System image file is "flash:c880data-universalk9-mz.150-1.M3.bin"
https://supportforums.cisco.com/thread/2061590
Hello!
On my routers I am able to configure OSPF with the advipservices licences, with both IOS 15.0M and 15.1T.
If you are still unable to configure OSPF with the same settings I suggest you open a TAC case.
AlbaTros#sh ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M2, RELEASE SOFTWARE (fc2)
[snip]
    License Level: advipservices   Type: Evaluation
AlbaTros#sh run | b router ospf
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
AloueTTe#sh ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
[snip]
AloueTTe#
AloueTTe#sh run | b router ospf
router ospf 1
passive-interface Vlan1
network 0.0.0.0 255.255.255.255 area 1
Herve
