OSPF into iBGP
raphaelblanks
Good Morning Everyone,
I have two routers: Router1 with iBGP and OSPF routing processes. Router1 has iBGP to Router2, and OSPF to an external router over Tunnel100. I am redistributing the OSPF routes into iBGP using the following:
"redistribute ospf 1 metric 100 internal external 1 external 2"
This works. I see all OSPF routes in the routing table of Router1.
I do not see any OSPF or iBGP routes on Router2, although I do see a neighbor-ship between the two.
Router1 sees routes from Router2.
No route-maps, prefix-lists, or ACLs are in play. What is going on??
Thank you for your assistance.
hard to say...can you post the configs of R1 and R2 ?
Hello
Its not clear on your topology, you mention ibgp peering between the two rtrs but no ebgp connections and also ospf, Can you post the diagram please
Kind Regards
Paul
reading through your post again: on which router are you redistributing OSPF into BGP ?
You would see the OSPF routes in the routing table of Router 1 regardless of the redistribution...so I am not really clear on which router the redistribution is taking place, maybe I am missing something...
In theory, a simple configuration such as the one below should work:
R1
router ospf 1
router-id 1.1.1.1
network 0.0.0.0 255.255.255.255 area 0
router bgp 1
bgp router-id 1.1.1.1
bgp log-neighbor-changes
redistribute ospf 1 metric 100 match internal external 1 external 2
neighbor 192.168.12.2 remote-as 1
R2
router bgp 1
bgp router-id 2.2.2.2
neighbor 192.168.12.1 remote-as 1
