OSPF ip sla default routing internet failover
J_Vansen_S
Level 3
Level 3
Hi All,
Currently entire network is under ospf area 0 with internet traffic in DC routed out to ISP 1, and DR internet traffic routed out to ISP2.
We have a requirement to do a routing failover from DC to DR when Internet connectivity to ISP1 is down. It would failover to use DR's ISP 2.
What method should i use to achieve this?
I have tried the below config on DR router but it did not work as expected.
ip sla 1
icmp-echo 8.8.8.8 source-ip 172.16.5.1
threshold 2
timeout 1000
frequency 3
access-list 101 permit icmp host 172.16.5.1 host 8.8.8.8 echo
ip sla schedule 1 life forever start-time now
track 100 ip sla 1 reachability
ip local policy route-map DR_RP
ip route 0.0.0.0 0.0.0.0 172.16.5.2 track 100
ip route 0.0.0.0 0.0.0.0 172.17.17.2 200
route-map DR_RP permit 10
match ip address 101
set ip next-hop 172.16.5.2
set interface Null0
Appreciate any advise at all
since you have blanked out the networks you are advertising, we cannot see which network is used to connect the DR and the DC.
The failover route doesn't look right:
ip route 0.0.0.0 0.0.0.0 172.17.17.2 200 --> where is that IP adress ? It needs to be at the DC site, and the DR site needs to have an IP address from that range, for the next hop to work.
Hello
What you have specified is static route ip sla tracking which looks correct and should work accordingly however you mention ospf so are the dc's ospf peering with the isp's, If they are opsf peering then wouldn't you want conditional tracking of ospf instead, please confirm?
Kind Regards
Paul
jcyc
Hi J_VANSEN_S, What L3 switch model did you use in building A?
if you want to use an IP SLA, you can trigger an EEM script:
DC Router
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 8.8.8.8 source-ip 172.17.17.1
frequency 5
router ospf 1
default-information originate metric 100
event manager applet ISP_1_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "router ospf 1"
action 4.0 cli command "no default-information originate metric 200"
action 5.0 cli command "end"
event manager applet ISP_1_UP
event track 1 state up
action 4.0 cli command "default-information originate metric 200"
DR Router
router ospf 1
default-information originate metric 210
