ospf nssa and default-gateway
bellocarico
Let's say I've got 3 routers
R1 -- R2 -- R3
R1 and R2 are in area 0
R2 and R3 are in area 1 nssa
R3 runs also RIP and redistributes rip into OSPF. So it's an ASBR.
Now, how do I make R1 learn about this default route coming from R3?
I've tried already:
1) create a static route on R3 + redistribute static subnets under OSPF --> no luck
2) Still on R3 under ospf router config: default-information originate always --> no luck
Thanks to read!
5 Replies 5
devang_etcom
Level 7
Level 7
will you please post the out put of show run...
regards
Devang
To generate a default route in NSSA ASBR, use the command 'area (#) nssa default-information-originate' under the OSPF process. A default route needs to exist in the routing table for this to work.
Sundar
Hi there,
You need "area nssa default-information-originate" on the ABR (R2 in your case) --> For NSSA a Type 7 default route is injected into the NSSA Area.
As stated by Cisco:
"The ABR originates the 0.0.0.0 type 7 LSA, even though it does not have a default route."
How OSPF Injects a Default Route into a Not So Stubby Area:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9fa.shtml
r2.2.2.2#show ip route 0.0.0.0
% Network not in table
r1.1.1.1#show ip route ospf
O IA 6.0.0.0/8 [110/65] via 5.0.0.2, 00:00:18, Serial2/1/0
O*N2 0.0.0.0/0 [110/1] via 5.0.0.2, 00:00:18, Serial2/1/0
HTH, Please rate if it does,
Mohammed.
The original poster wants to originate default route on R3, which is an ASBR, for which you need to have to have a default route in the routing table to originate one. What you are saying is true only the if the router originating the default route is an ABR.
From CCO;
Default Type 7
The following configuration generates a type 7 default route. You can configure this command on any NSSA ASBR or NSSA ABR with the following rules:
* NSSA ASBR can generate a default only when it has a default route in its routing table.
* NSSA ABR can generate a default route with or without a default route in its own routing table.
The following command is used to generate an NSSA default route:
router ospf 1
area 1 nssa default-information originate
http://www.cisco.com/warp/public/104/nssa.html
Sundar
Hi Sundar,
I totally agree with you, and i am sorry for seeing the original poster's request the other way round.
regards,
Mohammed.
