ospf over frame-relay and bgp
Kishor2125
I have a problem in ospf over  Frame-relay.  initially my network was working fine then
i lost all the routes in R1, It will not learn routes from ospf or bgp over F-r nor it is advertising the routes to the network
I have the complete detail config, sh and verifying info in a text file attached.
plse help
Kishor Garewal
cadet alain
For the OSPF in R1-R3-R4, on R1 you didn't set the ospf network type to point-to-multipoint so it defaults to NBMA but on R3 and R4 you did.
change the ospf network type on R1 and it should solve th OSPF problem.
For BGP I must still look at your config a little bit more.
Regards.
Alain.
Hi Cadetalain,
Thx for the help, u r right. it worked and surprisingly it also worked for the
bgp.
i do not see the connection. thanks again
Kishor
As in your zip file you didn't do any BGP related show commands, It's a little hard for me to see the connection as I've not really looked at the config
thoroughly.
But I'm happy it solved all your problems.
Regards.
Alain.
it was very basic fundamentals. iBGBP rides over IGP and thus first i had
fr-relay for conectivity, then ospf n then BGP if my ospf fails thus bgp is
effected.  When i fixed the ospf, BGP was back on.
thx for u help again.
Kishor Garewal
