OSPF overload
lrinetti62
Hi All
i use Cisco router together with some
Juniper router. During maintenance time i
use the "set protocol ospf overload" in
Juniper to turn off traffic. It exists a
similar command in Cisco IOS (avoiding tu put a high OSPF cost on each interface) ?
5 Replies 5
vladrac-ccna
Level 5
Level 5
Hello, I really dont know anything about Juniper, so could you explain what this command do, and what you are looking for when you implemented it?
Vlad
devang_etcom
Level 7
Level 7
hi...
To configure the router to signal other routers not to use it as an intermediate hop in their shortest path first (SPF) calculations, use the set-overload-bit command in router configuration mode. To remove the designation, use the no form of this command.
set-overload-bit [on-startup {seconds | wait-for-bgp}] [suppress {[interlevel] [external]}]
please rate this post if it helps
regards
Devang
Isnt this used for ISIS?
If what he's looking for is similar to what you've added , then, he's looking for:
max-metric router-lsa
To configure a router that is running the Open Shortest Path First (OSPF) protocol to advertise a maximum metric so that other routers do not prefer the router as an intermediate hop in their shortest path first (SPF) calculations, use the max-metric router-lsa command in router configuration mode. To disable the advertisement of a maximum metric, use the no form of this command.
max-metric router-lsa [on-startup {seconds | wait-for-bgp}]
no max-metric router-lsa [on-startup {seconds | wait-for-bgp}]
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_osph.htm#wp1001316
Vlad
