OSPF Pocess-ID
M.Sultan
Hi guys
I understand the purpose of Process-ID in OSPF domain, it's locally significant, two adjacent routers can form adjacency even with two different Process-ID.
Consider the Diagram :
R1 Area 0      R2 ABR          R3 Area 1
when i put interfaces from ABR into different Process-ID it doesn't form adjacency.
Like: in ABR
#Router ospf 20
#interface ethernet 0/0
#ip ospf 20 area 0
ABR #router ospf 40
#exit
#interface ethernet 0/1
#ip ospf 40 area 1
it does not form adjacency between router R1
Area 0 and R3 Area 1.
16 Replies 16
"if we put each interface into different Process-id, No adjacency will form."
Again, you need to be clear what you mean by
adjacency
, as for OSPF, it generally refers to two neighboring OSPF routers establishing an OSPF relationship between themselves.
On the same router, using different OSPF process IDs, there would be two distinct OSFP databases, one for each process ID.
Adjacency
doesn't apply between process IDs.
To clarify this even further, for process-ID 20 you might have connections to two different routers, one in
area 0
and one in
area 1
, and they would establish adjacency with R2 for both
areas 0 and 1
would be in one
OSPF topology.
You can do this again for process-ID 40, i.e. have another two routers, with adjacency with R2, in
area 0 and area 1.
However, although there's two sets of
area 0 and area 1
connected to R2, they are that, two sets, i.e. two
area 0s, and two area 1s
, and the two
area 0s
are NOT the same
area 0
, ditto for the two
areas 1.
What can make the forgoing confusing, R2 will route between both OSPF
topologies
, i.e. process-ID 20 packets can be directed to process-ID 40, and the converse, because both are combined in one routing table on R2 (unless using VRF).  But, by default, a non-R2 router in one of the two OSPF
 topologies
, would not "know" of the OSPF routes within the other OSPF
topology.
R1(OPSF1AREA0)-(OPSF1AREA0)R2(OSPF2AREA1)-(OSPF3AREA1)R3
here since area match between two routers the adj will form even if process is mismatch
Now'
In R2 since you run two process you need
redistrubte
from one process to other.
