OSPF router-id
Hi All,
I am in a strange situation here. I understand that the highest IP address assigned to any interface becomes the router-id and it gets beaten by the loop back even if the ip is lower. Please let me know if I am wrong.
But here I am not able to find that out. I have two routers
R1
Router(config)#do sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  administratively down down
Serial1/0                  10.10.13.1      YES manual up                    down
Serial1/1                  10.10.12.1      YES manual up                    up
Serial1/2                  unassigned      YES unset  administratively down down
Serial1/3                  unassigned      YES unset  administratively down down
Loopback1                  1.1.1.1         YES manual up     up
Router(config)#do sh run | s ospf
router ospf 10
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.10.12.0 0.0.0.255 area 0
network 10.10.13.0 0.0.0.255 area 0
R2
Router(config)#
*Mar  1 00:09:40.999: %OSPF-5-ADJCHG: Process 10, Nbr 10.10.13.1 on Serial1/0 from LOADING to FULL, Loading Done
The router-id still seems to be the higher IP address configured on physical interfaces. Any reason why?
Cheers!
Ravi
16 Replies 16
Hi Peter,
Yes, you are right. I manually added the router-id manually and did the clear ip ospf process. It shows instantly. But if I add an loopback interface once the router ID has already been decided clearing IP ospf process does not change the router ID. only way is to reboot the applaince.
thanks and cheers!
Ravindra
Thanks Rick.
Cheers!
Ravi
