OSPF routing case study
AllezLom63194
Level 3
Level 3
Hello the community,
You can find attached the case study topology and routers configurations.
For information :
- Site routers are ISR4331
- Dc routers are ASR1001-x router
- These routers can accept by default 16 différents path to join a network and seems to make load sharing between thes path.
I have severals questions:
1- On the router R1 and R2 I can annonce the network 10.45.208.0/20 using a "network 10.45.208.0/20 area 0 and passive inerface" or "redistribute connected"
1a - What is the best practise and why ?
1b - If I use redistribut conected the router becomes an ASBR router ?
2- What is the role of the back to back links between routers ?
3- On the DC Main router interface Fa3 I have ip ospf cost 100. It mean that all the routes learned by this interface will have OSPF cost of 100.
3a - So how can be sure that it will use Site Main router to join the green network (10.1465.0.0/16) ?
3b - Same question to join the red network (10.45.208.0/20) ?
Your brains are welcoms.
Thanks in advance
Regards.
AllezLom63194
Level 3
Level 3
The PDF file seems not working.
So here is the topology on jpeg format.
Regards.
AllezLom63194
Level 3
Level 3
Hi the community,
Nobody has any idees to help me.
This case study will help me to implement real network architecture.
Regards.
Is there somone that can tell me if the attached file are readable ?
I can "open/see" both PDF and JPG attachments.
