OSPF Routing Problem
wasiimcisco
I am facing problem in Routing in between head office and DR (disaster recovery) Side.
I have two links to my DR Side. I have GRE Tunnel with Primary and Secondary Router located in head office.
I want DR to use the Primary Router (tunnel 550) as primary link and Secondary IPVPN Router (Tunnel 540) as backup.
But I am not able to achieve this. I have even shut down the GRE tunnel (540) on Secondary IPVPN Router but still the traffic is going through this link. I am not able to track which path the traffic is taking. My bandwidth graph is high on on Secondary IPVPN link and Hardly few kbps is being used on the primary IPVPN link.
This means that something is wrong with the routing. Please go through the configuration and let me know what i am missing and which link cost I need to modify in order to use exact require link.
32 Replies 32
   If Tunnel 540 is up with ip ospf cost 50 command,  ENOCDC_R03 will go to 192.168.10.x(DR) via this link. Right?  Please post "show ip route 192.168.10.0 255.255.255.0" while Tunnel 540 is up.
Toshi
My object is traffic for subnet 192.168.200.0/24 use tunnel 550 always. But this is not happening even while shut down the tunnel 540. My bandwidth graph etc all showing traffic is going to Secondary IPVPN Link as mention prviously in the post by attaching the bandwidth graph.
ENOCDC_R03#sh running-config interface tunnel 540
Building configuration...
Current configuration : 306 bytes
interface Tunnel540
description connected to the DR-Site
bandwidth 1024000
ip address 172.27.5.37 255.255.255.252
ip mtu 1476
ip policy route-map RE_ROUTE>RACK2
ip ospf network point-to-point
ip ospf cost 50
keepalive 5 3
tunnel source GigabitEthernet0/0
tunnel destination 192.168.253.25
end
ENOCDC_R03#show ip route 192.168.10.0
Routing entry for 192.168.10.0/24
  Known via "ospf 1", distance 110, metric 41, type intra area
  Last update from 192.168.0.40 on GigabitEthernet0/1, 1w2d ago
  Routing Descriptor Blocks:
  * 192.168.0.146, from 172.27.1.10, 1w2d ago, via FastEthernet0/0/0
      Route metric is 41, traffic share count is 1
    192.168.0.40, from 172.27.1.10, 1w2d ago, via GigabitEthernet0/1
   Do you want DR-Router to always send 192.168.200.0/24 back via Tunnel550?. Right? Please post "show ip route 192.168.200.0 255.255.255.0" on DR-Router while Tunnel-540 is up.
   Edit: Sorry guys, I know it's a production now but we sometime need to verify the problem like this. In DR-Router point of view if it can learn 192.168.200.0/24 via ENOCDC_R04# and ENOCDC_R03#  we should not have a problem with modifing to select a preferable path in this case.
Toshi
Show ip route when tunnel 540 is down.
ENOC_DR_R01#show ip route 192.168.200.0
Routing entry for 192.168.200.0/24
  Known via "ospf 1", distance 110, metric 60, type extern 1
  Last update from 172.27.5.165 on Tunnel550, 00:01:23 ago
  * 172.27.5.165, from 192.168.0.162, 00:01:23 ago, via Tunnel550
      Route metric is 60, traffic share count is 1
ENOC_DR_R01#show ip ospf interface brief
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Fa0/0        1     0               192.168.10.2/24    1     DR    0/0
Tu550        1     0               172.27.5.166/30    10    P2P   1/1
Tu540        1     0               172.27.5.38/30     20    DOWN  0/0
show ip route when tunnel 540 is up.
Tu540        1     0               172.27.5.38/30     20    P2P   1/1
  Last update from 172.27.5.165 on Tunnel550, 00:00:11 ago
  * 172.27.5.165, from 192.168.0.162, 00:00:11 ago, via Tunnel550
I want DR Router should use tunnel 550 as long as it is up. Once tunnel 550 down. DR should start sending traffic to Tunnel 540.
  As fas as I can see, it worked as expected.
Tunnel550 is up & Tunnel540 is up
ENOC_DR_R01 is using Tunnel550 for 192.168.200.0/24 network.
Tunnel550 is up & Tunnel540 is down
HTH,
Toshi
Unfortunately this is not happening. If you see the above attached bandwidth graph it is clearly showing that the traffic is not going to the ENOCDCR04 Link.
Whatever we want to send to DR from the head office side. It is utilizing the ENOCDCR03 Link. I dont know what is happening. Apparently everything seems to be okay but when actual traffic is going it is not taking the right path.
See above graph.
what happens when you shut the Tunnel 550? and then check the routing on the DR.
Kishore
  Please post the output of  ENOC_DR_R01#traceroute 192.168.253.1 and ENOC_DR_R01#traceroute 192.168.253.37.
  To verify the traffic from DR to Primary router. Please add the following commands.
Conditions:
1. Tu550 and Tu540 are up
2. There are connections between 192.168.10.0/24 to 192.168.200.0/24.
#############ENOCDC_R04##############
ip access extend TEST-DR-192.168.10.0-IN-R04
permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255
permit ip any any
ip access extend TEST-DR-192.168.10.0-OUT-R04
permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip any any
ENOCDC_R04#conf t
ENOCDC_R04(conf-t)#interface g0/0
ENOCDC_R04(conf-if)#ip access-group TEST-DR-192.168.10.0-IN-R04  in
ENOCDC_R04(conf-if)#ip access-group TEST-DR-192.168.10.0-OUT-R04  out
Please post the output of  show access-list TEST-DR-192.168.10.0-IN-R04 and show access-list TEST-DR-192.168.10.0-OUT-R04
#############ENOCDC_R03##############
ip access extend TEST-DR-192.168.10.0-IN-R03
permit ip any any
ip access extend TEST-DR-192.168.10.0-OUT-R03
permit ip any any
ENOCDC_R04#conf t
ENOCDC_R04(conf-if)#ip access-group TEST-DR-192.168.10.0-IN-R03  in
ENOCDC_R04(conf-if)#ip access-group TEST-DR-192.168.10.0-OUT-R03  out
Please post the output of  show access-list TEST-DR-192.168.10.0-IN-R03 and show access-list TEST-DR-192.168.10.0-OUT-R03
Toshi
I will apply the Access-list at night because this is production and i need to process the change management procedure. Below is the trace ouput.
ENOCDC_R04#traceroute 192.168.253.37
Tracing the route to 192.168.253.37
  1 172.27.5.166 0 msec 4 msec 4 msec
  2  *  *  *
  3  *  *  *
  4 192.168.253.37 0 msec *  0 msec
ENOCDC_R04#
Tracing the route to 192.168.253.1
  1 192.168.253.26 4 msec 4 msec 0 msec
  2 192.168.253.2 12 msec 0 msec 0 msec
  3 192.168.253.1 0 msec 0 msec
ENOCDC_R03#traceroute 192.168.253.1
  1 192.168.0.146 0 msec
    192.168.0.40 0 msec *
ENOCDC_R03#traceroute 192.168.253.25
Tracing the route to 192.168.253.25
  1 192.168.253.38 16 msec 8 msec 0 msec
  2 192.168.253.26 4 msec 8 msec 4 msec
  3  *  *
I have make both the tunnels up and applied the access-list but nothing is coming in the access-list.
We are running GRE so i think we need to apply the access-list on the Tunnel interfaces ???????. Below are the results when both the tunnels are up and traffic is passing between Head office and DR.
ENOCDC_R03#show access-lists TEST-DR-192.168.10.0-IN-R03
Extended IP access list TEST-DR-192.168.10.0-IN-R03
    10 permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255
    20 permit ip any any (447337 matches)
ENOCDC_R03#show access-lists TEST-DR-192.168.10.0-OUT-R03
Extended IP access list TEST-DR-192.168.10.0-OUT-R03
    10 permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255
    20 permit ip any any (418554 matches)
ENOCDC_R03#show ip ospf interface brief
Gi0/1        1     0               192.168.0.39/27    30    DR    1/1
Lo0          1     0               192.168.0.161/32   1     LOOP  0/0
Fa0/0/0      1     0               192.168.0.145/30   30    P2P   1/1
Tu540        1     0               172.27.5.37/30     50    P2P   1/1
  Last update from 192.168.0.40 on GigabitEthernet0/1, 14:36:28 ago
  * 192.168.0.146, from 172.27.1.10, 14:36:28 ago, via FastEthernet0/0/0
    192.168.0.40, from 172.27.1.10, 14:36:28 ago, via GigabitEthernet0/1
ENOCDC_R04#show access-lists TEST-DR-192.168.10.0-IN-R04
Extended IP access list TEST-DR-192.168.10.0-IN-R04
    20 permit ip any any (103308 matches)
ENOCDC_R04#show access-lists TEST-DR-192.168.10.0-OUT-R04
Extended IP access list TEST-DR-192.168.10.0-OUT-R04
    20 permit ip any any (135906 matches)
ENOCDC_R04#show ip ospf interface brief
Gi0/1        1     0               192.168.0.40/27    30    BDR   1/1
Lo0          1     0               192.168.0.162/32   1     LOOP  0/0
Fa0/0/0      1     0               192.168.0.146/30   30    P2P   1/1
Tu550        1     0               172.27.5.165/30    10    P2P   1/1
ENOCDC_R04#show ip route 192.168.10.0
  Known via "ospf 1", distance 110, metric 11, type intra area
  Last update from 172.27.5.166 on Tunnel550, 1w4d ago
  * 172.27.5.166, from 172.27.1.10, 1w4d ago, via Tunnel550
      Route metric is 11, traffic share count is 1
Both the Tunnel 540 and 550 is up and show ip route of DR router
  Last update from 172.27.5.165 on Tunnel550, 00:01:32 ago
  * 172.27.5.165, from 192.168.0.162, 00:01:32 ago, via Tunnel550
Ahhh, sorry guys my fault. packets are already encasulated before hitting ACL.  Please put ACLs on the tunnel interfaces.
Toshi
I have applied the acl on tunnel interfaces.
When Tunnel 540 is active and Tunnel 550 is down.  I can see the traffic on this tunnel 540.
    10 permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255 (11277 matches)
    20 permit ip any any (715 matches)
    10 permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255 (507 matches)
    20 permit ip any any (72 matches)
    10 permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255 (514 matches)
    20 permit ip any any (74 matches)
ENOCDC_R03#sh run interface tunnel 540
Current configuration : 404 bytes
interface Tunnel540
bandwidth 1024000
ip mtu 1476
ip ospf cost 50
keepalive 5 3
end
When Tunnel 550 is active and Tunnel 540 is also active.  I can see the traffic on this tunnel 550.
nterface Tunnel550
ip address 172.27.5.165 255.255.255.252
ip mtu 1476
ip policy route-map RE_ROUTE>RACK1
ip ospf cost 10
keepalive 5 3
end
    10 permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255 (15589 matches)
    20 permit ip any any (2405 matches)
    10 permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255 (21917 matches)
    20 permit ip any any (2150 matches)
interface Tunnel540
bandwidth 1024000
ip mtu 1476
ip ospf cost 50
keepalive 5 3
end
    20 permit ip any any (264 matches)
When Tunnel 550 is active and Tunnel 540 is down.  I can see the traffic on this tunnel 550 only
    10 permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255 (23386 matches)
    20 permit ip any any (2513 matches)
   The routing is working correctly.  Do you still see wrong information in your network monitoring?
Toshi
THanks for the continous help. Actually i couldnt tested throughly. Inface I have applied the QOS through Packet shaper for this link because of this routing proble. I will once again go through the change mangement process to disable the QOS and then I will ask the other team to push the traffic to DR.
I want to clear few things regarding cost Please correct me if i am calculating the right cost. I have included the LAN Cost of each Router  as well during this cost calculating.
OSPF cost from DR to R03     ---------------------------------------> (1+20+30)=51  cost of lan of DR is 1, DR tunnel cost is 20 and cost of R03 Lan is 30
OSPF cost from R03 to DR     -----------------------------------------> (30+50+1)=81
OSPF cost from R03--->R04---->DR     -------------------------> (30+30+10+1)=71
OSPF cost from DR to R04     ----------------------------------------> (30+10+1)=41
OSPF cost from R04 to DR     -----------------------------------------> (30+10+1)=41
OSPF cost from R04--->R03---->DR     -------------------------> (30+30+50+1)=111
   You need to specific the network to calculate the cost.
R04  point of view , Go to 192.168.10.0/24
Cost = 1+10 = 11  , (Cost of LAN on DR  + Cost of Tunnel 550 on R04)
Primary IPVPN#show ip route 192.168.10.0
  Last update from 172.27.5.166 on Tunnel550, 1w0d ago
R03 point of view  Go to 192.168.10.0/24
Cost = 1+10+30 = 41  , (Cost of LAN on DR  + Cost of Tunnel 550 on R04 + Cost of GigabitEthernet0/1 on R03)
DR point of view  , Go to 192.168.200.0/24
Cost = 50+10 = 60 , ( O*E1 Cost from R04  +  Cost of Tunnel550 on DR )  External Cost + Cost to ASBR
####Check the external cost for 192.168.200.0 on DR####
ENOC_DR_R01#sh ip ospf database external 192.168.200.0
< 50="">    <-----  You should see this line.
HTH,
Toshi
