03-20-2012 03:26 AM - edited 03-04-2019 03:43 PM
have two path to reach R2 ospf neighborship is up and working find. I had a problem with the connectivity between R1&R2 for Path A hence the routing got converged and used Path B to reach R2 but when the R1 and R2 connectivity issue got resolved it did not switch back to Path A .
R1--------R2 (path A)
R1------R3----R2 (path B)
Any clue what would have happened
Solved! Go to Solution.
03-20-2012 03:37 AM
Hi Mani ,
Did you or any colegue changed the cost between R1 and R2 ? Did the adjacency when to Full between R1 and R2 ?Also you can check the database for prefiexs generated by R2 in order to see if they are also received via direct link.
Dan
03-20-2012 03:37 AM
Hi Mani ,
Dan
03-22-2012 01:55 PM
Thanks Dan it helps, the interface had a ospf cose set, so the path had lower opsf cost than the directly connected path. hence path B was installed in the routing table.
~EM
