OSPF routing
hdev0
Community Member
Why does OSPF operates like a distance vector protocol in inter-area routing ?
balaji.bandi
Can you explain more, why you thinking that way, any evidence to understand better ?
BB
Based on advertisement flooding of Type 3 LSA into the other areas ?
Joseph W. Doherty
Basically, it's what the committee decided on. Pros and cons likely were much influenced by router hardware at the time. I.e. if it was designed today, good change another approach might be chosen. For example, the later designed OSPFv3 isn't just OSPFv2 supporting 128 bit addresses.
