OSPF split horizon and default route
Stanko Jankovic
Does split horizon prevent the advertisement of the default route over the interface which is the outgoing interface of the default route (when default-information originate is configured in OSPF)?
Bilal Nawaz
No, the split horizon rule runs in EIGRP, RIP to prevent routing loops - preventing the route it learned through one interface and advertising back out the same interface. OSPF is a link state protocol working out the topology by building the shortest path tree, so split horizon rule does not count in OSPF.
With the default-information originate command the router must know its own default route already to be able to advertise this default route, it generates a type 5 LSA in to the ospf database. However, if you want to forcefully advertise the default route, without containing a default route in the routing table, then have the 'always' key word.
router ospf 1
default-information originate always
Hope this helps
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9f0.shtml
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
router ospf 1
Hope this helps
