unable to get DHCP address on WAN interface C2621
gergokarpati
Dear All,
anyone can help with the issue?
I have read a lot and tried everything and nothing seems to solve the issue.
I have a C2621 where with the default config (after reload no initial config taken) aftert an erase nvram.
so the router is literally blank.
here is the config:
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
ip classless
gatekeeper
shutdown
line con 0
speed 115200
line aux 0
line vty 0 4
end
Only Thing modified is the ip address dhcp on fa 0/0.
no IP address is assigned to the interface.
the modem I use... have to use is a Cisco EPC3925 ( from the ISP (UPC) ) in bridge mode.
If I put any Win 7 or whatever PC on to that modems one of the 4 fa interfaces they get an ip.
the debug output from dhcp:
Router(config-if)#no shut
Router(config-if)#
*Mar  1 00:01:52.767: DHCP: DHCP client process started: 10
*Mar  1 00:01:52.767: RAC: Delaying starting DHCP because interface FastEthernet0/0 not up
*Mar  1 00:01:54.759: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
Router(config-if)#
*Mar  1 00:03:19.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Mar  1 00:03:19.847: DHCP: DHCP client process started: 10
*Mar  1 00:03:19.847: RAC: Starting DHCP discover on FastEthernet0/0
*Mar  1 00:03:19.847: DHCP: Try 1 to acquire address for FastEthernet0/0
*Mar  1 00:03:22.351: DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x26DD29B9
*Mar  1 00:03:24.871: DHCP: allocate request
*Mar  1 00:03:24.871: DHCP: new entry. add to queue
*Mar  1 00:03:24.871: DHCP: SDiscover attempt # 1 for entry:
*Mar  1 00:03:24.871: DHCP: SDiscover: sending 298 byte length DHCP packet
*Mar  1 00:03:24.871: DHCP: SDiscover 298 bytes
*Mar  1 00:03:24.871:             B'cast on FastEthernet0/0 interface from 0.0.0.0
*Mar  1 00:03:25.147: DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x83145218
*Mar  1 00:03:25.307: DHCP: Received a BOOTREP pkt Not for us..:  xid: 0xFE4183EB
*Mar  1 00:03:26.027: DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x83145218
*Mar  1 00:03:27.427: DHCP: Received a BOOTREP pkt Not for us..:  xid: 0xAA3768E3
*Mar  1 00:03:27.871: DHCP: SDiscover attempt # 2 for entry:
*Mar  1 00:03:27.871: DHCP: SDiscover: sending 298 byte length DHCP packet
*Mar  1 00:03:27.871: DHCP: SDiscover 298 bytes
*Mar  1 00:03:27.871:             B'cast on FastEthernet0/0 interface from 0.0.0.0
*Mar  1 00:03:30.111: DHCP: Received a BOOTREP pkt Not for us..:  xid: 0x1BC6120C
*Mar  1 00:03:30.871: DHCP: SDiscover attempt # 3 for entry:
*Mar  1 00:03:30.871: DHCP: SDiscover: sending 298 byte length DHCP packet
*Mar  1 00:03:30.871: DHCP: SDiscover 298 bytes
*Mar  1 00:03:30.871:             B'cast on FastEthernet0/0 interface from 0.0.0.0
SDiscover attempt # 3 for entry: stops and retries after 60 sec.
possible causes so far, that cannot be the cause
no access list is blocking udp traffic (blank config)
no Layer 1 issues (tried several cables which all work elswhere fine.),
bootp protocol may mess things up --- ip dhcp bootp ignore --- the same.
set the MAC to something else (dlink router or so.), no use
if the EPC3925 is not in bridging mode and is the DHCP Server the same applies.
the wonder of all is, my brother has a Dlink router and if I plug in the router's (2621) fa 0/0 to one of the Dlinks ports guess what happens?
any help idea (even if it is to change the ISP) is appreciated.
Than you all in advance!
9 Replies 9
Jeff Van Houten
Level 5
Level 5
Have you tried port 0/1 on the 2621?
Thank you Jeff for your reply,
I just tried it and it is the same. if I use the EPC3925 as DHCP no BOOTP packets are present, but still no dhcp address is leased, and this applies to both interfaces on the 2621.
Guess it is time to call the provider, as the error must be on their end...
Hello
Try using a crossover cable and reboot the modem.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
gergokarpati
Dear pdriver,
thank you for the suggestion, sonds silly, I do not know if have tried it or not will definitely do and see if that makes a difference, but the point is good, thank you again!
gergokarpati
Nothing seems to help... a 2620XM as dhcp server leases an address, a dlink, whatever leases an address. only the ISP and the ISP's modem not... however if I set it up as 192.168.1.1 255.255.255.252 and the router is the x.2 and than I have my own subnet with double NAT... :S speed is somehow decreased to 1/2... according to the provider noone had the same issue... the 2620XM cannot get an ip also something with UPC devices vs cisco... funny is upc uses cisco gear... anyway thanks for the suggestions so far, I will try to find a solution, and I am also open for any other suggestions.
Manually configure the MAC address on the interface like below...
find the mac address of the interface from 'show interface fa0/0'
interface fa0/0
ip dhcp client-id hex XXXX.XXXX.XXXX <---- fa0/0 mac address in this format
ip dhcp client hostname Router
ip address dhcp
Let us know if this works.
hth.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Dear Bilal,
Thank you for the suggestuin, unfortunately I cannot enter the command ip dhcp client-id hex.
I tried it via:
int fa 0/0
     mac-address xxxx.xxxx.xxxx
     ip address dhcp
but in such a case no debug output is shown, as nothing would happen.
If I remove the manually configured MAC the debug is the same, and no IP is given.
Can you try one of these 2 commands
under interface:
ip dhcp  client client-id f0/0
no ip add dhcp
ip add dhcp
or
-under interface:
no ip add dhcp
ip add dhcp client-id Fastethernet0/0
Alain
If you configure a Cisco router as a DHCP client, it may use a weird client-id in its DHCP requests. Instead of using the interface MAC address as the client ID (as most workstations do), the client ID is the string 'cisco-dotted.mac.ascii-ifname' where the dotted.mac.ascii is the interface MAC address in ascii and the ifname is the short interface name.
The format may not be understood by the DHCP server so its just about getting your router to send the correct client-id in its request. Perhaps Alains suggestion will work. I know the hex one works but doesnt seem supported on your router.
hth
