Ospf state INIT and not FULL
iccjflores
Hello i have a problem beacuse the ospf protocol can´t pass to FULL state, this said that is INIT, the configuration in both interface are:
R_1#sh int multilink 11R_2#sh int multilink 11
Multilink11 is up, line protocol is up Multilink11 is up, line protocol is up
  Hardware is multilink group interface  Hardware is multilink group interface
  Description: R_2  Description: R_1
  Internet address is 172.16.49.17/30  Internet address is 172.16.49.18/30
  MTU 4470 bytes, BW 9920 Kbit, DLY 20000 usec,   MTU 4470 bytes, BW 9920 Kbit, DLY 20000 usec,
     reliability 255/255, txload 1/255, rxload 1/255     reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Open, multilink Open  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, TAGCP, CDPCP, loopback not set  Open: IPCP, TAGCP, CDPCP, loopback not set
  Keepalive set (10 sec)  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset  DTR is pulsed for 2 seconds on reset
  Last input 00:00:00, output 00:00:03, output hang never  Last input 6d21h, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:14:12  Last clearing of "show interface" counters 3d14h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)  Output queue: 0/40 (size/max)
  5 minute input rate 0 bits/sec, 0 packets/sec  5 minute input rate 0 bits/sec, 0 packets/sec
  5 minute output rate 0 bits/sec, 0 packets/sec  5 minute output rate 0 bits/sec, 0 packets/sec
     1137 packets input, 52394 bytes, 0 no buffer     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)     Received 0 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 0 throttles      0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     840 packets output, 13440 bytes, 0 underruns     109525 packets output, 9386764 bytes, 0 underruns
     0 output errors, 0 collisions, 0 interface resets     0 output errors, 0 collisions, 0 interface resets
     0 output buffer failures, 0 output buffers swapped out     0 output buffer failures, 0 output buffers swapped out
     0 carrier transitions     0 carrier transitions
R_1#sh run int multilin11R_2#sh run int multili11
interface Multilink11interface Multilink11
mtu 4470 mtu 4470
ip address 172.16.49.17 255.255.255.252 ip address 172.16.49.18 255.255.255.252
ip ospf cost 7999 ip flow ingress
ip ospf mtu-ignore ip ospf cost 7999
logging event link-status ip ospf mtu-ignore
logging ip access-list cache in logging event link-status
logging ip access-list cache out mpls label protocol ldp
mpls label protocol ldp mpls ip
mpls ip ppp multilink
ppp multilink ppp multilink links minimum 1
ppp multilink links maximum 5 ppp multilink group 11
ppp multilink links minimum 1 service-policy output TK-MPLS
ppp multilink group 11end
end
Only on R1 i see the state of INIT
R_1#sh ip ospf neighbor R_2#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
150.220.250.180   0   INIT/  -        00:00:36    172.16.49.18    Multilink11
Jan Hrnko
Level 4
Level 4
there seems to be something wrong with your interface on R2. It has NO inputs whatsoever.
Your show ip ospf neighbor output just underlines this fact.
The INIT state on R1 means, that R1 has received a hello packet from R2, but R1 can't see its own ID included in R2's hello packet. When a router receives a hello packet from a neighbor, it should list the sender's router ID in its hello packet as an acknowledgment that it received a valid hello packet. If it doesn't, OSPF remains stuck in INIT.
So, your output clearly says that R1 is sending hello packets and receiving some, but not with its own ID in it. R2 is sending hello packets to R1, but isn't receiving any.
The problem seems to be in underlying technology - link itself or the interface - have you tried to ping that interface? It shouldn't work.
I am sorry, but I don't know how to fix this, I just saw that you want make OSPF work but the problem seems to be somewhere else, not in OSPF itself or anything related to it.
Best regards,
Jan
Jan Hrnko
Level 4
Level 4
Best regards,
Jan
iccjflores
Thanks....
ok, Ready...
when i make a ping between R1 and R2 don´t answer...
I do reset of interface because this have a problem with the Overload traffic and this bloked and dont work
This does sound like a connectivity issue between the two routers.
Can you post the output of 'show ip ospf int mu11' for me?
The link between these two routers, is this something you control, or is it provider equipment?
I also see 'mpls ip' is on each one, but labels are created from IGP.
Would it hurt anything to take off the 'mpls' config and try a test ping?
Hi...
Here is the command...
  Internet Address 172.16.49.17/30, Area 0
  Process ID 1, Router ID 150.220.250.1, Network Type POINT_TO_POINT, Cost: 12500
  Topology-MTID    Cost    Disabled    Shutdown      Topology Name
        0           12500     no          no            Base
  Transmit Delay is 1 sec, State POINT_TO_POINT
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:08
  Supports Link-local Signaling (LLS)
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 16/16, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 1, maximum is 39
  Last flood scan time is 0 msec, maximum is 8 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 150.220.250.180
  Suppress hello for 0 neighbor(s
Yes i have the control, the interface is saturated and bloeked,which although the status and protocol are up.
Apparently is a BUG so I'll have to upgrade the IOS
