OSPF Type-3 default route LSA metric
Sam-CCNP
Does anyone know if there is a way to change the metric of a
Type-3 default route LSA?
The purpose is to influence the exit point for traffic in a totally stubby area with two ABRs.
Thanks.
Sam
2 Accepted Solutions
Harold Ritter
Hi @Sam-CCNP ,
You can use the following command command on the ABR to set the cost value on the default injected in the stub area:
router ospf <process-id>
area <x> default-cost <cost>
Hello
If you which to influence which ABR is used, you could set a maximum metric  to the least preferred
rtr
router opsf x
max-metric router-lsa summary-lsa
Kind Regards
Paul
8 Replies 8
M02@rt37
Hello @Sam-CCNP,
To influence the exit point for traffic, you can manipulate the OSPF cost on the interface connecting to the totally stubby area to indirectly influence the preferred exit point.
Best regards
Hi, thanks for responding.
I think maybe I worded my question poorly. It's the traffic exiting the stub area i want to influence, not entering.
And as it's a tsa, traffic uses the
 type 3 default route
, which is the metric I want to influence.
Thanks. Sam
Blue_Bird
You can change with following commands.
(config)#router ospf <process>
(config-router)#default-information originate [always] [metric <metric>] [metric-type {1|2}]
Hi @Blue_Bird ,
This is the command you would enter if you wanted to originated the
default route
as an external
ospf route
. In a totally stubby area, the
default route
is already injected as an
inter area route
. This is the one for which @Sam-CCNP wants to change the metric.
Harold Ritter
Hi @Sam-CCNP ,
Thanks. Thats the one. Brain got lazy and gave up quickly.
As an aside, what if I left one ABR configured as a stub but the other ABR as a totally stuby area by adding no-summary? That would result in the more specific inter-area routes being propagated into the area from one router, making it the preferred exit point.
I know it sounds strange, but I'm studying for my CCIE lab, whose solutions sometimes do not reflect reality (I've heard).
Hello
rtr
router opsf x
Kind Regards
Paul
I just looked up that command and applied it to the ABR in my lab, it worked so I'll try to remember that one too. Thanks!
