OSPF Vitual Link Issue
libra_ali786
My Topology.
Before creating OSPF Virtual Link between R1&R2 , routing table getting inter area route (circle with red color). I understood with no doubt. The table belong to R2 Router.
But, After creating OSPF Virtual Link between R1&R2 , routing table getting intra area route (circle with red color). Why it change Inter area route into Intra route? I think so it should be inter area route instead Intra area ?
Note : The table belong to R2 Router.
Hello
@libra_ali786 wrote:but why OSPF VL change Inter to Intra? is because of VL?
YES
Kind Regards
Paul
13 Replies 13
how did you configure the VL ? Post the full configs of R1 and R2...
libra_ali786
R1#show run | sec ospf
router ospf 1
 area 1 virtual-link 192.168.23.2
 network 1.1.1.0 0.0.0.255 area 0
 network 30.30.30.0 0.0.0.255 area 1
 network 192.168.12.0 0.0.0.255 area 1
R2#show run | sec osp
router ospf 1
 area 1 virtual-link 30.30.30.1
 network 192.168.23.0 0.0.0.255 area 2
the VL config does not look right. In your case, area 1 is the transit area, so all interfaces should be in area 1. R3 is the other end of the virtual link, so R1 needs to establish the VL with R3, and vice versa. So your configs should look something like the below (I used loopbacks to establish the virtual link):
router ospf 1
area 1 virtual-link 3.3.3.3
network 1.1.1.1 0.0.0.0 area 0
router ospf 1
network 192.168.23.0 0.0.0.255 area 1
R3#show run | sec osp
router ospf 1
area 1 virtual-link 1.1.1.1
network 3.3.3.3 0.0.0.0 area 2
Hello
That because router 2 is now connected to the BB router 1 via the VL in area 0 thus an intra-area route.
Kind Regards
Paul
As per OSPF  multi-area scenario we always get an Inter area routes between different area pass by BB. am i right?
do you actually get the Virtual Link working with your config ? Can you post the output of 'show ip ospf virtual-link' from both sides of the link ?
Yes.
R1#show ip ospf v
Virtual Link OSPF_VL0 to router 192.168.23.2 is up
  Run as demand circuit
  DoNotAge LSA allowed.
  Transit area 1, via interface FastEthernet0/0
 Topology-MTID    Cost    Disabled     Shutdown      Topology Name
        0           1         no          no            Base
  Transmit Delay is 1 sec, State POINT_TO_POINT,
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    Hello due in 00:00:08
    Adjacency State FULL (Hello suppressed)
    Index 1/2, retransmission queue length 0, number of retransmission 0
    First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
    Last retransmission scan length is 0, maximum is 0
    Last retransmission scan time is 0 msec, maximum is 0 msec
R2#show ip os v
Virtual Link OSPF_VL0 to router 30.30.30.1 is up
  Transit area 1, via interface FastEthernet2/0
        0           1         no          no            Base
    Hello due in 00:00:07
    Index 1/3, retransmission queue length 0, number of retransmission 0
post the full configs of all three routers, not just snippets. I cannot recreate your setup in GNS3, I get an error about a backbone area mismatch...
R1#show running-config
Building configuration...
Current configuration : 1155 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
interface Loopback1
 ip address 1.1.1.1 255.255.255.0
interface Loopback99
 ip address 30.30.30.1 255.255.255.0
 ip address 192.168.12.1 255.255.255.0
 duplex full
 no ip address
 shutdown
 speed auto
 duplex auto
interface FastEthernet2/1
 no ip address
 shutdown
 speed auto
 duplex auto
router ospf 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R2#show running-config
Current configuration : 1019 bytes
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
 no ip address
 shutdown
 duplex full
 ip address 192.168.12.2 255.255.255.0
 speed auto
 duplex auto
 ip address 192.168.23.2 255.255.255.0
 speed auto
 duplex auto
router ospf 1
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R3#show running-config
Current configuration : 1030 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
interface Loopback1
 ip address 10.10.10.1 255.255.255.0
 ip address 192.168.23.3 255.255.255.0
 duplex full
 no ip address
 shutdown
 speed auto
 duplex auto
 no ip address
 shutdown
 speed auto
 duplex auto
router ospf 1
 network 10.10.10.0 0.0.0.255 area 2
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
the main reason your VL is misconfigured is the lines marked in bold. You are trying to establish the VL using area 1 as transit area, and with the other side, 30.30.30.1 also being in area 1. The VL might be up but it isn't working. You need to link to something in the backbone area, area 0. That is the whole idea of a virtual link.
R1
router ospf 1
R2
router ospf 1
Have a look at the document below, it has a fairly simple sample setup involving three routers:
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/47866-ospfdb7.html
My 30.30.30.0 network is a loopback inerface. Thats why it does not matter "network 30.30.30.0 0.0.0.255 area 1"  because router ID always highest loopback IP.
But in other hand i put network 30.30.30.0 0.0.0.255 area 0  , but result was same. I mentiond in Bold.
R2#
Gateway of last resort is not set
      1.0.0.0/32 is subnetted, 1 subnets
O        1.1.1.1 [110/2] via 192.168.12.1, 00:20:34, FastEthernet2/0
      10.0.0.0/32 is subnetted, 1 subnets
O        10.10.10.1 [110/2] via 192.168.23.3, 00:20:54, FastEthernet2/1
      30.0.0.0/32 is subnetted, 1 subnets
O        30.30.30.1 [110/2] via 192.168.12.1, 00:02:27, FastEthernet2/0
      192.168.12.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.12.0/24 is directly connected, FastEthernet2/0
L        192.168.12.2/32 is directly connected, FastEthernet2/0
      192.168.23.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.23.0/24 is directly connected, FastEthernet2/1
L        192.168.23.2/32 is directly connected, FastEthernet2/1
Hello
YES
Kind Regards
Paul
Thanks Paul driver. i accept your solution. but i nedd some more techinal detial which i got.
