OSPF
aayush998
Community Member
I Configured 3 routers connected to each other in a triangle shaped topology to run OSPF. Apart from the basic configuration i did not not change anything else. However, on running " show ip ospf interface brief" command" on any of the three routers, the cost for the FastEthernet Interfaces interface on that router is 10 and the cost for the loopback interface is 1. The reference BW on each router is 100Mbps. What could be the reason?
farcosre
Hello. It seems  that is represented by auto-cost reference-bandwidth 1000 (check the image added).
To return to the default reference bandwidth, use the auto-cost reference-bandwidth 100 command in ospf configuration in each router, and then ask the same command.
farcosre
hi farcosre
thank you for the response. the reference BW on my routers was already 100. I used the command you suggested and changed it to 10. the cost on all the interfaces is 1 now.. i'm not sure if that is how it is supposed to be
May be it is the version IOS, it is pretty strange behavior , can you share me an screenshot of your version ios in order to test that?
thanks!!
regards
Please find the attached images
