OSPFv3 - TSA (Totally Stuby Area) missing the default route?
FlorianCokl
Hello Networkers,
There is a simmilar post regarding ospfv2 - but mine is about ospfv3 configured with
router ospfv3 <proc-id>!
The links are configured with ipv4 and ipv6 addresses. The area 6 stub works - but (in my case) area 62, on R1 gets the
area 62 stub no-summary
configured - as I have learned for decades. It doesn't matter if the
latter
command is configured under the address-family or the "just under the routing process, above the adddres-families" - the results are the same = no default route on "my" R62?!
The LSDB, however, has the route - I just can't see the difference?
R62 is (of course) configured with
area 62 stub
"only", since the
no-summary
is only necessary on the ABR (R1 in my case).
26 Replies 26
Hello MHM
Which machines would you like to have the show output from?
How would I be able to share the exportet Lab?
If you can share only
Show ospfv3 of
R1
R6
R62
If you can,
I need it for failure not succes case
Yes - shure one moment, please - just fired it up again....
Your comment is delete?
What? Ok - I'll try it in three steps.
R1 running on IOL!
R1#sh ospfv3
OSPFv3 1 address-family ipv4
Router ID 1.1.1.1
Supports NSSA (compatible with RFC 3101)
Supports Database Exchange Summary List Optimization (RFC 5243)
Event-log enabled, Maximum number of events: 1000, Mode: cyclic
It is an area border router
Router is not originating router-LSAs with maximum metric
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Minimum LSA interval 5 secs
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Retransmission limit dc 24 non-dc 24
EXCHANGE/LOADING adjacency limit: initial 300, process maximum 300
Number of external LSA 5. Checksum Sum 0x02F7A5
Number of areas in this router is 3. 1 normal 2 stub 0 nssa
Graceful restart helper support enabled
Reference bandwidth unit is 100 mbps
RFC1583 compatibility enabled
Area BACKBONE(0)
Number of interfaces in this area is 3
SPF algorithm executed 4 times
Number of LSA 60. Checksum Sum 0x247286
Number of DCbitless LSA 0
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
Area 6
Number of interfaces in this area is 1
It is a stub area
Generates stub default route with cost 1
SPF algorithm executed 2 times
Number of LSA 42. Checksum Sum 0x16DAFA
Flood list length 0
Area 62
It is a stub area, no summary LSA in this area
SPF algorithm executed 3 times
Number of LSA 7. Checksum Sum 0x058C79
Flood list length 0
OSPFv3 1 address-family ipv6
Router ID 1.1.1.1
Number of external LSA 0. Checksum Sum 0x000000
Area BACKBONE(0)
Number of LSA 45. Checksum Sum 0x19CA5F
Flood list length 0
Area 6
It is a stub area
Number of LSA 30. Checksum Sum 0x100512
Flood list length 0
Area 62
Number of LSA 6. Checksum Sum 0x041B95
Flood list length 0
R6 running on IOL
R6#sh ospfv3
OSPFv3 6 address-family ipv4
Router ID 6.6.6.6
Number of areas in this router is 1. 0 normal 1 stub 0 nssa
Area 6
Number of interfaces in this area is 5
It is a stub area
Number of LSA 45. Checksum Sum 0x188110
Flood list length 0
OSPFv3 6 address-family ipv6
Router ID 6.6.6.6
Area 6
It is a stub area
Number of LSA 33. Checksum Sum 0x12BF91
Flood list length 0
R62 former IOL now vIOS
R62#sh ospfv3
OSPFv3 62 address-family ipv4
Router ID 62.62.62.62
Area 62
It is a stub area
Number of LSA 10. Checksum Sum 0x07CD5E
Flood list length 0
OSPFv3 62 address-family ipv6
Area 62
It is a stub area
Number of LSA 9. Checksum Sum 0x05B17F
Flood list length 0
R1 (running IOL!!)
R1#sh ospfv3
Router ID 1.1.1.1
Area BACKBONE(0)
Flood list length 0
Area 6
It is a stub area
Flood list length 0
Area 62
Flood list length 0
Router ID 1.1.1.1
Area BACKBONE(0)
Flood list length 0
Area 6
It is a stub area
Flood list length 0
Area 62
Flood list length 0
R6 (running IOL!!)
R6#sh ospfv3
Router ID 6.6.6.6
Area 6
It is a stub area
Number of LSA 45. Checksum Sum 0x1928BC
Flood list length 0
Router ID 6.6.6.6
Area 6
It is a stub area
Number of LSA 33. Checksum Sum 0x11454F
Flood list length 0
R62 (former IOL now vIOS!!)
R62#sh ospfv3
Area 62
It is a stub area
Number of LSA 10. Checksum Sum 0x07E154
Flood list length 0
Area 62
It is a stub area
Number of LSA 9. Checksum Sum 0x05CF70
Flood list length 0
thanks a lot for your reply,
final request can you share the failed vIOS R62 show ospfv3
Ah - underneath....
