OSPv3...from Global Configuration or Interface Mode?
1.) Do you configure it from Global Configuration mode or per Interface?
2.) Do you have to have a loopback already created before configuring the router-id
Some of the configuration is done in global mode and some under each interface.
Just a raw example:
Global :
ipv6 router ospf 1
router-id 2.2.2.2
default metric 30
Under interface:
interface f0/0
Ipv6 enable
ipv6 ospf 1 area 0
Router-id is an optional command. If you do not specify router-id command, router picks the highest IP address of a loopback interface.  Having loopback interface is also optional. If you want router to pick your loopback address as a router id, you need to create loopback at first. If you do not do that, you need to restart your ospf process to fix that.
Hope it helps,
Masoud
