Other Routing
gowdakssujan
Capture.PNGDoes interface G0/0 of Router4(11.0.0.2) can be pinged/reachable from PC3?
2 Accepted Solutions
Jon Marshall
If PC3 has a default gateway of 10.0.0.1 and router 4 has a route for 10.0.0.0/24 with a next hop IP of 11.0.0.1 and there are no acls in place then yes.
Jon
It will be dropped at R4.
Routing is a two way thing ie. just because there is a path one way does not mean there is a path back so when you troubleshoot routing issues you have to remember to trace the path both ways and check for routes to and from the destination.
Jon
Jon Marshall
Jon
Okay...If I haven't configured a route to 10.0.0.0/8 in R4. And PC3 has a default gateway of 10.0.0.1 and no ACL. Where does the packet will be dropped, when I ping from PC3 to 11.0.0.2???
Jon
