OTV and Multicast
maverick-lamont
Hey Guys,
So I have setup the below lab and I am having trouble with the OTV adjacency finding the routers in the other site.
Lab Site 1:
  • 1 ESX Host
  • 1 WEB Server ( vlan 400)
  • 2 x CSR 1000v
    • Gi1 - WAN
    • Gi2 - 300
    • Gi3 - MGMT
    • Gi4 - Trunk(vlan 400 and will trunk more when lab is working)
  • 1 HP 1910 Switch
  • VLAN's trunked to ESX host
  • Access VLAN 300 patches to Switch in Site 2.
Lab Site 2:
  • 1 ESX Host
  • 2 x CSR 1000v
    • Gi1 - WAN
    • Gi2 - SITE LINK (VLAN 300)
    • Gi3 - MGMT
  • 1 Cisco C3548XL switch.
All routers have a port directly connect to VLAN 300 and configured with a 10.0.0.0/24 IP. All routers can ping each other and they have peered using iBGP. I have OSPF configured for internal VLAN's at each site that I dont want to extend with OTV and have BGP redistributing OSPF.
The OTV is peering with the other router in its site but not detecting the routers at the other site.
IP IGMP snooping is not running.
Config:
ip multicast-routing distributed
interface GigabitEthernet2
ip pim passive
ip igmp version 3
otv site-identifier 0001.0001.0001 #0002.0002.0002 for site 2.
interface Overlay1
otv control-group 239.37.37.37
otv data-group 232.37.37.0/24
otv join-interface GigabitEthernet2
no shutdown
If I change the OTV config to unicast it works fine but it is not recomended to do it this way and you can only specify 2 IP's when manually setting the adjacency.
Any ideas of where I should focus my efforts to troubleshoot would be much appreciated.
David
20 Replies 20
It doesn't seem to be AED capable anymore, anything else that you changed? Before it seemed fine from your screenshots, it just needed a WAN neighbor to operate fully.
The very fact the pim neighborship does not come up between both sites is a problem.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
It is because I turned off the second router that was in the same site.    Because it had adjacency with that CSR it was AED capable.    The problem is getting adjacency with the other site.   If I move one of the CSR's so that they are both in the same site everything works fine,  OTV works.
No, the router should be AED capable without the second router. It is not necessary that you have to have two routers for a router to become AED capable, thats just silly right? Unless this is some weird limitation which i very much doubt that Cisco would have introduced.
You need multicast to work across to the other site. I think, after the discussions we have had, the transport network between seems to be the cause.
I will try to get hold of CSR's VM'd up and see if I can replicate your situation. I'll post current configs with ASR1002's with point to point connections with OTV working.
Out of interest, this is the first time I have come across OTV with the virtual appliances hosted on ESX hosts, is this going in production?
This is the config guide I originally followed:  http://www.layerzero.nl/blog/2013/05/otv-and-lisp-on-the-csr-1000v/
Worked first time but I was using a single ESX host.
We are planning to deploy OTV,   so was just wanting to get familiar with it in a virtual lab.
I agree that it is probably the switch between the site,  unfortunaly I am out of decent lab equipment.
I will try deploy them in our production ESX tomorrow and see if I can atleast bring the OTV with a decent switch in between.
David
This router (ASR1002-x) has point to point links to DC and other sites with OTV functioning. Mainly going towards the DC - N7K which is interface Te0/3/0
otv site bridge-domain 8
otv site-identifier 0000.0000.0010
track 1 interface TenGigabitEthernet0/3/0 line-protocol
interface Loopback0
description PIM-RP-ADDRESS
ip address 192.168.255.1 255.255.255.255
ip pim sparse-mode
ip ospf 1 area 0
interface Loopback1
description PIM-ANYCAST
ip address 192.168.255.11 255.255.255.255
ip pim sparse-mode
ip ospf 1 area 0
interface Overlay1
no ip address
otv control-group 239.1.1.1
otv data-group 238.1.1.0/28
otv join-interface TenGigabitEthernet0/3/0
interface GigabitEthernet0/0/0
description ## S-ASR-WAN01 ## REFXXXX ##
mtu 9216
ip address 192.168.143.1 255.255.255.252
ip pim sparse-mode
ip ospf network point-to-point
ip ospf bfd
ip ospf 1 area 0
ip ospf cost 1000
negotiation auto
bfd interval 50 min_rx 50 multiplier 5
cdp enable
interface GigabitEthernet0/0/1
description ## S-ASR1002-01 ## SHUK ##
mtu 1700
ip address 192.168.230.34 255.255.255.252
ip pim sparse-mode
ip ospf bfd
ip ospf 1 area 0
shutdown
negotiation auto
cdp enable
interface TenGigabitEthernet0/1/0
description ## ASR routing to ASR-WAN02 ##
mtu 9216
ip address 192.168.110.1 255.255.255.252
ip pim sparse-mode
ip ospf bfd
ip ospf 1 area 0
cdp enable
interface TenGigabitEthernet0/2/0
description ## Trunk to 6509E-VSS01 - OTV & ROUTE ## Te1/2/1 ##
no ip address
cdp enable
service instance 8 ethernet
  encapsulation dot1q 8
  bridge-domain 8
interface TenGigabitEthernet0/2/0.1111
description ## P2P to 6509E-VSS01 - ROUTE ## Te1/2/1 ##
encapsulation dot1Q 1111
ip address 192.168.111.1 255.255.255.252
ip pim sparse-mode
ip ospf bfd
ip ospf 1 area 1
description ## P2P to DC1-N7K-WAN01 - ROUTE ## Ex/x ##
mtu 9216
ip address 192.168.11.2 255.255.255.252
ip pim sparse-mode
ip igmp version 3
ip ospf bfd
ip ospf 1 area 0
cdp enable
router ospf 1
router-id 192.168.111.1
auto-cost reference-bandwidth 100000
passive-interface default
no passive-interface GigabitEthernet0/0/0
no passive-interface TenGigabitEthernet0/1/0
no passive-interface TenGigabitEthernet0/2/0.1111
no passive-interface TenGigabitEthernet0/3/0
ip pim rp-address 192.168.255.1
ip pim ssm default
ip msdp peer 192.168.255.12 connect-source Loopback1
ip msdp peer 192.168.101.3 connect-source Loopback1
ip msdp peer 192.168.201.3 connect-source Loopback1
ip msdp cache-sa-state
ip msdp originator-id Loopback1
ip msdp mesh-group MSDP-DC 192.168.101.3
ip msdp mesh-group MSDP-DC 192.168.201.3
event manager applet Int-Down
event track 1 state down
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "interface overlay 1"
action 1.3 cli command "shutdown"
event manager applet Int-Up
event track 1 state up
action 1.3 cli command "no shutdown"
Thanks,    yeah I guess the point ot point is just part of their OSPF config.
Moved the CSR's to our production and ESX and it worked immediatly,  it has to be that HP swithc in the middle.
for the the help.
