Output bottleneck CF981F router
etsoft
i'm getting 750 Mbps speed from my ISP , this router is only outputting 375 Mbps. What could be the cause of this?
Erwin
Leo Laohoo
Router cannot support 750 Mbps.
definitely cant support that agree , these are Soho routers
You need a 4k 44 or 45 model at least for that or an ASR but if you want to do it a lot cheaper an RV router may suit depending on size of network get you close to it but these are not enterprise level routers and are GUI
https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-742350.html
https://www.cisco.com/c/dam/en/us/products/collateral/routers/900-series-integrated-services-routers-isr/q-and-a-c67-741630.pdf
